IP Device Falling Offline
I have an IP controlled device that falls offline at random times. I am running known-good code, used in many other systems with no problems
I am noticing that it takes longer to come online than usual. Here are the internal messages at boot-up. The device in question is 0:5:14. I have no log of what happens when it goes offline at this point.
Any suggestions appreciated.
Line 1 (17:25:18):: UNKNOWN HOST: utcnist.colorado.edu
Line 2 (17:25:18):: ClientOpen mxInetAddr or hostGetNyName error 0x0
Line 3 (17:25:18):: CIpSocketMan::ProcessPLPacket - Socket Already Closed
Line 4 (17:25:18):: CIpSocketMan::ProcessPLPacket - Socket Already Closed
Line 5 (17:25:18):: CIpEvent::OnError 0:3:14
Line 6 (17:25:18):: CIpSocketMan::ProcessPLPacket - Socket Already Closed
Line 7 (17:25:18):: CIpEvent::OnError 0:5:14
Line 8 (17:25:18):: CIpEvent::OnLine 0:5:14
Line 9 (17:25:18):: CIpEvent::OnError 0:3:14
Line 10 (17:25:18):: CIpEvent::OnError 0:3:14
Isn't IP port 5 dedicated internally for the time update? I know we avoid ports 0-8 as internal use, we start at 10 for things we attach. If I'm not way off here, the attempt to do the time update (every 2-4 hours) uses port 5 to do it. Note that your log starts with the failed time lookup. Try a port above 8.
1) Could be DNS resolution error
2) Could be firewall rule at switch/router blocking WAN access.
-John
Usually only ports 1 & 2(?) are reserved for use by the master. I start my usage at 3.
If that's true, that's another reason to not use FIRST_LOCAL_PORT, as it's set to 2.
Kevin D.
I think the intent of FIRST_LOCAL_PORT was to act as a base for addition. Like FIRST_LOCAL_PORT + 1 to equal the first port used (port 3) or FIRST_LOCAL_PORT + 2 to equal the sencond port used (port 4), etc and not to be used all by itself. I'm sure when they created the Netlinx.axi it made sense to the creator but I think he's the only one that would find it useful. Not to knock on the creator since I tend to do stupid $hit like that too sometimes and never go back to remove it even after I realize how stupid it really is.
No one told the help file guy:
I don't use it, but it's crazy how it exists being how bad it can be (when used in compiled modules). I suppose if they ever start using port 2 for something, a new version of NS will come out and change FIRST_LOCAL_PORT to 3.
Any one know if the master allocates ports up to the max like the touch panels do? IE, if I start at 0:10:0, does 2-9 get created automatically?
Kevin D.
I was taught that port 3 is the first usable port for our purposes as well. In the case of my problem system, port 3 is the iTime manager, and port 5 is my problem device. There are no other IP devices, hardware or virtual in the system.
I also avoid first_local_port. I beleive I was discouraged of using it in my PII class way back when.
Further, I never define devices (or ports) in modules. That completely defeats the purpose of making modules that are portable and reusable.
The other errors are just normal IP connections stuff. A connection will often break before fully recognized by the master, which is where that socket error comes from. That will settle down in a few seconds.
This constant is available for assignment.
INTEGER FIRST_LOCAL_PORT = 2;
// example
dvSocket1 = 0:FIRST_LOCAL_PORT:0
dvSocket2 = 0:FIRST_LOCAL_PORT+1:0
