TPD4 Button disabled state
nicoladicosmo
I'm working with a general button, If it is set as Disabled (General Properties select 'Yes' from the drop-down) can I assign to it a diferent image? and if yes, How?
I've to change the button type to have this?
ND
ND
Should be possible with the following command
if you want to do multiple buttons you can by doing xxx.xxx so 500.515 would be button 500 to button 515.
0 = all state
1 = off state
2 = on state
This can also be found in the PI.
Not positive if this also works if the button is disabled, but I imagine it should.
thanks for your answers
I'm not schizophrenic or anything
