iPort FS22 doesn't work with iPhone 3G?
I have a system with 5 iPorts, running the latest module (3.23), and it works great, EXCEPT if we plug in an older iPhone 3G. The 3GS works just fine, as do all the other versions of iPods. Just not the 3G, it simply will not dock. I've tried several 3G phones, some running IOS 4 and others that are on earlier versions. Neither works.
Anyone else seen this problem? Very odd.
(I haven't tested an iPhone 4 yet, so I don't know if that works or not)
Chuck
    Dock firmware?
    We've seen a number of can't-read issues with iPhones if the dock hasn't got the latest firmware.... less than 6 months old... it's a pain to update (or even to check it!), you need to make or get a special cable from Sonance and use their utility software... so many people don't do it. Do it.
  • chuckdchuckd Posts: 26
    Thanks, I was hoping to not have to do that, but I guess I don't have anything else to try.
    Now time to rig up a cable!
    Chuck
