Samsung LED TVs
jamesrdelaney
Hi
Anyone know if the 'service port' on the back of the Samsung TVs can be used for RS232 control similar to the Pioneer plasmas (RIP).
I rang Samsung and they dont support it.
James
James
And running IR just to turn it on and serial for all the inputs & power off commands would just be a waste. So, if I were you, I'd just jam the flasher up through the metal sheet on the back of the TV if you don't want the flasher on the front of the beautiful looking display.
Samsung tech support is a joke . . . don't waste your breath.
Kevin D.
See attached zip file...
Has anyone found discrete power commands for these displays? The remote it comes with just has a power toggle button.
Power On:
0000 0059 0000 0022 00D1 00D1 0019 004D 0019 004D 0019 004D 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 004D 0019 004D 0019 004D 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 004D 0019 0019 0019 0019 0019 004D 0019 004D 0019 0019 0019 0019 0019 004D 0019 0019 0019 004D 0019 004D 0019 0019 0019 0019 0019 004D 0019 004D 0019 0019 0019 08B1
Power Off:
0000 0059 0000 0022 00D1 00D1 0019 004D 0019 004D 0019 004D 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 004D 0019 004D 0019 004D 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 0019 004D 0019 004D 0019 0019 0019 0019 0019 004D 0019 004D 0019 004D 0019 004D 0019 0019 0019 0019 0019 004D 0019 004D 0019 0019 0019 08B1
To give credit where it is due... these were all pulled from the Samsung Discretes 08 remote in the installer generated RTI IR library.
http://a248.e.akamai.net/pix.crutchfield.com/manuals/305/30561a750.pdf
I use this protocol for model LN-XX and UN-XX. Uses a header of "$08,$22" followed by 4 bytes, then a checksum(two's complement of the previous). Also, it worked out of the box, and the power on command works.
Hope it helps!
Is that for displays with a 9 pin 232 port, or the Ex-Link port?
Pinout was:
AMX Pin 2 - Tip
AMX Pin 3 - Ring
AMX Pin 5 - Sleeve
Has anyone tried controlling the Samsong LED series 6, UA55C6900VR over IP or HDMI thro CEC. The client doesnt like the IR emitter to be placed on the front. Any guidance will be appreciated
Working on a project with 4 Samsung LED Displays. I've spent hours trying to get the IR to work on the units. It seems like the emitters only work out of the shell. Any tips or tricks appreciated.
David Groves
DG Sales and Service
Works but is incomplete.
You the man! is working great, where did you get the protocol for that ???
Could you please post it? I need the power commands and the discrete inputs to implement.
Criss
Thanks for posting this Nate! You saved me from having to dig for it
Here's the rudimentary module I threw together if anyone wants it. It doesn't do much, but it might save someone else a bit of typing. I tested this with a Series 6 650 LCD TV. This tv provides no feedback, not even the success/fail ack described in the manual, but at least all the discrete power and input controls work
Here are the commands I have received from Samsung
Tried that, went on to something else after a fruitless 1/2 hour or so. I'm guessing its not in the same subset as the standard inputs.
