Vudu Module
jjames
This is ONLY a communication module. No UI module is provided. This has been tested on(and successfully controls) Vudu Boxes loaded with the most current firmware and is untested (and assumed not to work) with the Vudu software loaded on various devices (e.g. Samsung, Mitsubishi, LG, etc. televisions as well as Samsung, LG, etc. blu-ray players.)
As always, this code comes AS IS without any type of warranty. I will update as needed and when possible. Post or email bugs. Best viewed with tab and char settings both set to 3 and with a monospaced font such as Consolas.
If you don't like the formatting of the code, change it to your liking.
I have no idea, I would assume not though. I will test when I get home . . . I do have a Samsung BD-C5500 (it's a piece of junk BTW), with Vudu on it.
Anyway, I digress.
What's interesting about the boxes is that you can find dealers to buy them from . . . strangely we're dealers - so I'll have to ask my boss if the boxes are ACTUALLY available, though I highly doubt it . . . I just never heard of them totally stopping hardware production, but I don't pay too much attention to that stuff.
That was the word I got from my distributor last time I tried to place an order. A few weeks before that I got some for a job no problem.
*Replaced .ip_Address with .SOURCE_STRING to comply with original Netlinx.axi
Sorry! I modified my Netlinx.axi since "SOURCE_STRING" from the DEV_INFO_STRUCT wasn't very descriptive, so this is why it wouldn't compile.
Removed - see below
As for the Vudu box i have spoken to Vudu a few times and they have officialy been out of production for quite some time now. There are a few new ones left on amazon, but after those are gone its only used ones or unopened ones on Ebay. They have no plans of making the boxes again. they just simply did not sell enough for Vudu to make them.
Thanks Again
Saul
So, I loaded this up on an NI-3000 that was running 2.31.137 - and noticed that DEVICE_INFO on the master with non-duet version was not working properly.
So I removed DEVICE_INFO and replaced it with GET_IP_ADDRESS (a command I wasn't aware of) since all I was interested in was the IP.
