Can't config R-3
Hi all
I can the receiver in Netlinx but double click on it dose nothing, and when right click on it, the "Launch web control page" is disable...
Any ideas?
Ady.
    adys wrote: »
    Hi all
    Any ideas?
    Ady.
    Sounds like it might be a Bonjour (aka Zero Config) problem. Windows firewall likes to block Bonjour, try disabling it to see if that work. I've always found WIndows firewall to be only nominally useful, myself, I just shut it down and never looked back.
    I also had that exact problem, believe it or not, when I had a bad Ethernet cable going to a Zigbee gateway. It showed online, but apparently there were enough malformed packets that it couldn't connect well enough to run the config. The device even worked, though it went offline a lot. Replaced the cable, it started working just fine again.
  • adysadys Posts: 395
    updating firmware solve the issue from some reason... have no idea why
