MVP-5200i Hardware Issue
vining
I had a 5200i that was unresponsive, didn't re-act when docked, no display although presses on the screen did make the wheel light blink. I figured a hard reboot was in order so I removed the plastic tape and rubber feet that cover the screws that fasten the halves together and then realize that most of the brass bosses that the screws screw into are loose and the plastic part the bosses are press fit into are all split and broken.
To me this panel looked like it was never entered before since when you peel up the plastic cover it usually leaves a mark on it where it's been pried up so this is most likely a flaw in the material or manufacturing. If it rattles it's probably loose brass bosses.
Regardless the mounting posts and bosses are pretty crappy.
These are only 2 month old and we installed them in every bedroom on the night stand so yeah they're going to get slept on and bounced off the bed from time to time and I can understand them sustaining most types of damaged but these bosses and posts should be pretty indistructable. I would think I have to drive a car over them before they would break.
The way the plastic post are split it's as if the bosses used to press into place were a couple sizes too big so they just split the plastic like sections of an orange. I'm not saying QC is bad but when you open up a TP and pieces just fall out on the table it's not a good sign.
Again the miracle of duct tape saved the day. Just taped it back up, allowing access to the mic and stylus and stuck it back into the night stand. I'm sure to get a call when the clients come back and see this thing on the night stand. Fortunately this is in a guest bedroom so I may be able to get it replaced before they even notice. Plus this is a week end summer beach home so they may not be back for awhile, knock on wood.
lol, you've got to get a picture of that
You'll probably never get the customer to admit it, but my money is on them having dropped it on an edge, so the impact shattered the plastic boss mounts. They can probably handle as much stress as you feel they ought if dropped flat, but not the shear stress if one edge of the case encounters a sudden impact and the other half doesn't.
It may be as simple as using the wrong size bosses on the assembly line or maybe the plastic is out of spec and too brittle. Maybe it heat related break down of the plastic's elasticity that causes the outward pressure of the bosses to break through over time. Of course these have only been installed for a couple of month. I'm pretty good at thinking of ways a person can do all sorts of dumb things and I can't think of any way a person could cause this type of damage from the outside with out destroying the panel or leaving some signs of external abuse.
We have an installation of 8 5200 and have to replace them every 18 months or so due to battery swelling. I guess the firmware isn't turning off the charging once its fully charged or something, so they swell and then start doing weird things.
