Zones Help
I have been trying to wrap my head around the concept of zones but I am getting in over my head. I think it is because I am trying to create multiple zones across 2 video switches. Something smaller and simpler would probably be easier to understand. Here's a scenario:
1 room
1 master
1 panel
1 8x8 switch
2 displays (1 has audio the other is display only)
2 serially controlled cable boxes
2 IR controlled DVD players
The quick, no frills programming would be to create a new port for each device. No worries. That would work just fine. Now 6 months down the road, that customer uncovers a pot of money so they expand. They add 2 more panels, 2 more displays, and 4 more cable tuners. A programmer could create new ports for each new device, but the system would not be expandable friendly. Each panel needs to be able to control all devices. What would be the better way to make this system infinitely expandable? This is where zones and event tables come into play, correct?
1 room
1 master
1 panel
1 8x8 switch
If you know that the touch panel is selecting cable box 1 in room 1, you can send a command to the video switcher to make output 1 use input 1. You can make this more efficient by using arrays to determine what is connected where and you can condense the switching code to something as simple as:
define_function doVideoSwitch(integer myDevice, integer myRoom){ send_string dvVidSwt,"'CI',itoa(nInput[myDevice]),'O',itoa(nOutput[myRoom]),'T',10,13"; } . . . button_event[dvTP,BTN_SRC_SELECT]{ push:{ stack_var integer nTpIndex; stack_var integer nDevIndex; nTpIndex = get_last(dvTP); nDevIndex = get_last(BTN_SRC_SELECT); nSrcInUse[nTpIndex] = nDevIndex; doVidSwt(nDevIndex,nRoomInUse[get_last(dvTP)]); } }Hoep this helps,
It can get complicated. Don't forget that in addition to AV zones, you can also have HVAC zones, Security zones, Lighting zones, etc that may or may not correlate to your AV zones. You may need 2 AV zones called 'Living Room' and 'Dining Room' that require different AV settings, but for HVAC, there is only one zone since both rooms are on the same HVAC pump. However, in the living room alone there might be 10 security zones. Like others have said, the more time you spend thinking it all through before writing any code, the less code you end up writing.
So code-wise, if I'm dealing with an 8x8 Precis - I have 8 zones. If I have an output going to an Integra DTR hooked up to that 8x8 - I still have 8 zones, but if the DTR is not hooked up to it and is sort of its own little area - I now have 9 zones. If on that Precis I only have 2 outputs hooked up - I still have 8 zones. As Jeff said, tracking variables of the area your controlling and what you're controlling will help big time - however you do that, is up to you. Use channels on a virtual device, use levels, use a variable - whatever.
If my logic is way off base - some one advise.
For devices, I will share a single panel port for all simple controls: IR, basic RS-232 (i. e., limited feedback, not a lot going on), then run a test on the button event to determine what device gets it. To accomplish this, I use a variable that tracks what device each panel in the system is currently controlling, and switch it as new devices are selected. At that point, IR control is as easy as SEND_COMMAND dvControlled_Device[<panel index>], "'SP', BUTTON.INPUT.CHANNEL", and will work for any IR device you care to use ... just edit the button channels on the page to match the IR channels they fire.
I have found that many large systems wind up with multiple systems ... be it a multizone amp with a switcher, receiver for a local system, or just a TV. Once upon a time, I wrote a separate module for each system, but found it terribly cumbersome for all the individual modules to be aware of what was going on in the others. So I treat a house like one big system now, and create a structure tailored to the job that determines what controls each zone. The program then not only tracks what device each panel is controlling, but which zone, and a simple reference to the system structure tells whether to send those volume commands to the local TV, or an audio switch, or whatever. This also makes it easier to "move" control in a panel from one room to another if desired.
Zones are going to take more practice. 99% of my jobs are purely A/V, no lighting, HVAC, alarms, or anything else. Told you my jobs were boring, cookie cutter jobs.
Last night I was playing with my 10 month old daughter and it hit. My problem with "zones" was that I wasn't stepping back and looking at the big picture.
If I had a multi panel / one master system, in front of each panel I could place a coffee table. On that coffee table I can place all of the toys that particular panel is allowed to play with. When the master rx'd a "Channel UP" command, it would go something like this:
"Panel 1 just sent me a 'Channel Up' command. Looking at his coffee table, I see he can only play with Tuner 1, so I am going to relay the message to Tuner 1 that he needs bump up his current channel."
Taking it even further, I can put two tuners on Panel 1's table. Then it would go something like this:
"Panel 1 just sent me a 'Channel Up' command. Looking at his coffee table, I see he can only play with Tuner 1 and Tuner 2. He is currently asking for control of Tuner 2, so I am going to relay the message to Tuner 2 that he needs bump up his current channel."
And even further, I can have a "boss" panel:
"Uh oh. The 'Boss' Panel just sent me a 'Channel Up' command. Since he is the boss, he can play with all of the tuners. Right now, he is currently standing in front of coffee table 1 and the only tuners on coffee table 1 are Tuner 1 and Tuner 2. He has asked to control Tuner 2, so I need to tell Tuner 2 he needs bump up his current channel."
What toys I place on each coffee table, or zone, is totally up to me. I can place them by Audio, Video, or even get silly with it and place them by faceplate color, control methods, or names that rhyme with each other. It really doesn't matter. What does matter is that I divide the toys up in such a way as to make logical sense, ease of programming, and a way that would make things easier for expansion or for the next guy that comes along. That would be the difficult part and the part requiring the most planning. Now I just need to draw out my system, figure out the best way to divide the toys, and how many coffee tables I need. This is going to be fun.
In my one panel / one master systems, there are 2 "modes" the user can select: VTC or Local Presentation. I think I am going to start out by making each mode a zone. I think that would be the easiest, for now anyway. Then divide up the toys by which zone needs which devices and levels of control, and take it from there.
DEFINE_DEVICE dvTP_1 = 10001:1:0 dvSWITCH = 5001:1:0 dvCODEC = 5001:2:0 dvLFT_MON = 5001:3:0 dvRHT_MON = 5001:4:0 dvDVD_1 = 5001:9:0 DEFINE_CONSTANT DEV arrTP_MAIN[] = { dvTP_1 } DEV arrVIDEO_SWITCH[] = { dvSWITCH } DEV arrCODECS[] = { dvCODEC } INTEGER nCODEC_DEV_MAP[] = { 1 } DEV arrDVD_PLAYERS[] = { dvDVD_1 } INTEGER nDVD_DEV_MAP[] = { 1 } DEFINE_VARIABLE VOLATILE INTEGER nPNL_AV[MAX_PANELS] { nZone_TS } DEFINE_EVENT BUTTON_EVENT[arrTP_MAIN,nTransport_BUTTONS] { PUSH: { STACK_VAR INTEGER nIND STACK_VAR INTEGER nIR_FUNCTION nIR_FUNCTION = GET_LAST(nTransport_BUTTONS) nIND = GET_LAST(arrTP_MAIN) SEND_COMMAND arrDVD_Players[nDVD_DEV_MAP[nPNL_AV[nIND]]],"'SP',nIR_FUNCTION" } }If I did it right, this essentially gave the current panel control of Zone 1, and placed the current DVD player in Zone 1. In the past, I would have created dvDVD_TP 10001:2:0 and done this:
BUTTON_EVENT[dvDVD_TP,0] { PUSH: { SEND_COMMAND dvDVD_1,"'SP',BUTTON.INPUT.CHANNEL" }Now I am trying to utilize zones, and I am stuck. If I again start making ports for each device, that negates the need for zones. If I try to do most of my control from one port, I can't use BUTTON.INPUT.CHANNEL, because those channels are already being used somewhere else. To get around that, I created an array of transport buttons so I could utilize GET_LAST. Am I more or less working in the right direction? I am thinking with this method I can add panels or equipment and place them in their proper zones.I use a structure to describe each device and put the security limitations in it. The constants I use to reference the security level start at 1 for Unrestricted, 2 for Un-classified, 3 for secret.... etc. Since a un-classified device can be show/heard in a higher level classification (TS), the simple test against the room classification and the selection of a device to control (display or listen to) allows me to determine when to restrict acess. Each room has it's own classification, and each device in the room has a classification. An unrestricted device (like a projector) can always be utilized. This ensures that the user can't inadvertently show a classified PC in a unclassified briefing. Since we use multiple CODECs (classified/unclassified), they are also controlled by the Room Classification.
You might also want to consider writing your control code to a virtual device. The control of the CODEC in ROOM A, uses the same routines as one in ROOM B in our systems. I use a device array and a virtual device array that is in the same order. The get_last function returns the offset from the virtual device array, and the offset is used to control the real device from the device array. It's kind of like creating classes in Java, so the code doesn't need to change much. The Touch Panel can use the same buttons in each room, and use a touch panel device array to determine which room the touch panel is in to know where you're working too. The added benefit for us is that our customized IR Remote can control the devices as easily as a Touch-panel, and utilizes the same control routines.
Hope that gives you some additional ideas.
ROO
