Toshiba DVD-VCR Combo
I'm going crazy with this install, I still learning how to program touch panels and controllers. So far I was able to pull the code from a previus install and modify it to work with diferent projector (panasonic 80u) and switch scaler (kramer vp-724xl and Extron IN1508) and diferent dvd/vcr combo, but when I try to contron the Toshiba dvd-vcr the code does not switch from dvd to vcr. I tried to modify the IR file and added the vcr manually and the dvd manually but it does not change. I also make sure the code match the IR file numbers, any sugestions? Toshiba SD-V296 DVD/VCR Combo
