Home AMX User Forum AMX Resource Management Suite Software
Lamp Hour Reports are showing only one of 30 rooms online
When I run a lamp hour report, I only ever get info on a single room in the database. No matter what options I try, it always reports back that same single room. All of our users see this.
Any ideas? We are running the latest RMS on Server2008
Doug
  • Are you using a custom module or the AMX module for the projector?
  • dmenkedmenke Posts: 25
    I am using the AMX module. I am seeing lamp hours in each system, and they are correct, they just don't show up in the report when it is run.
  • Dave_UKDave_UK Posts: 54
    dmenke wrote: »
    I've seen this issue happen if RMS calculates the average lamp hour usage to be a negative value. If the average is a negative value then that venue doesn't show up in the reports.
    Not sure how exactly RMS calculates the average from the stored parameter data though.
    In our case I assume it's due to some erroneous values being occassionally reported back from the projectors which then results in a negative value appearing in the math, which is a condition that isn't accounted for in the calculations and breaks the report generation.
    Dave
