Wireless Telephones for Large Homes
bwestlake
Has anyone out there in the AMX residential world found a wireless telephone that works well in a 20,000 sq.ft.+ size home? Your recommendations would be appreciated.
A general rule of thumb is the higher frequency stuff has a more limited range and the lower goes a little farther watt-for-watt. Here again, a lot depends on things that are hard to measure.
You might look into wireless voip phones, but only if you can segment off your LAN. VoIP phones are notorious bandwidth destroyers. If you can partition off your LAN and wirless network (VLANs and managed wireless networks) you might get your gig done on one phone.
hope that helps.
The one home I'm dealing with now is loaded with stone, concrete, lathe + plaster, granite etc. Cellular reception is almost non-existent inside and marginal outside. We can scatter cordless phones around the house but the customer would like to be able to walk around the house on a call.
I second this. We've put in a few of these (dating back to the TAW848 hybrid) and the coverage is pretty freaking great. Good distance. We covered a very large estate (including out buildings, barn, horse shed) with four of the repeater stations.
