Power
Morning, I got a call from the VP of finance, and he is asking how much power does a CV5 touch panel consumes in a hour. I called AMX and they could not help me with that question. Does any body has an idea?
•Constant current draw: 650 mA @ 12 VDC
•Startup current draw: 1.3 A @ 12 VDC
But you have to add the loss in the power supply that provides the 12 VDC so you're probably talking 10 to 15 watts depending on the efficiency of the PS.
I know, this is pretty trivial.
Calculations based on manufacturer's published current draw specifications are probably not worth your time. Many tech tool suppliers have a power meter you can plug things into and get actual readings that will be much more than the totally theoretical info above. But the theoretical info may suffice in your case where it sounds like a non-tech wants assurance that these don't use as much power as the air conditioning or pool heater.
Which begs more questions... there's a heat output from both the power supply and the panel that could/should be calculated into the environmental control costs... just gets so fractional....
Thanks for the replys, so far we have 25 touch panels that stayed on since they got installed back in March 2009 untill I went for the installer certification in Las vegas and Ken show us how to modify the touch panels, is were I set them to turn off after 60 minutes and turn on when motion is detected. At the begining the VP did not want to pay for the certification, then when I came back from the training I showed the my suppervisors what I learned and that hows all if this started, and since the University is trying to cut on cost that is why the VP wants to know. So far the University wants to install AMX controllers and Touch Panels though all compus, is about 100 more units, so they want to pressent this info to the president of TAMIU to get approval.
The trainer was passing on both bad habits and blatantly incorrect information.
Not saying people can't learn useful information, but trying to shove something as sophisticated as programming in a few days of instruction and having a hard-headed, know-it-all instructor tends not to work so well.
I don’t think I’ve ever been to any kind of training where I didn’t take away at least one nugget of useful information.
Thanks for the implication. I'm flattered.
But hey, feel free to listen to interesting instructions like "compile your includes" because they WON'T include unless you compile them first. Make sure you do it in sCAPSLOCK too. It's cool if you don't want to understand what you're doing and how things work - we're just paid to MAKE things work, not to understand them, aren't we?
The three instructors that I have had (Dallas) understood Netlinx programming very well and all three taught good courses. I had some contact with an instructor in Atlanta when my continuing education practical for 2009 was graded and my impression is that he had a good and thorough understanding of Netlinx programming too. I suppose it's possible that there are AMX instructors who don't know what #include does, but I've not encountered them. As for sCAPSLOCK, I don't know what that is. There is a character in some John Sanford novels named Del Capslock, but I suspect that's something different.
Oh, I've had some experience with a support guy in Dallas and he always knows exactly what I'm talking about. Clearly the guy doesn't sit around picking his nose waiting for calls to come in. I'm sure that there are many here who know who I'm talking about and also greatly value his expertise and experience.
You've had a bad experience with an AMX instructor -- it's not the norm.
Re: support, they seem to know what they're doing and have generally been helpful, although I've certainly received some unexpected responses at times. Sadly, I've had to call them too many times. (I've only had to call the competition support once, but to be fair, the guy was completely wrong about what to do...but he DID lead me to where I screwed up - indirect help I guess...)
P.S. wasan't this post about 'power consumption' ?
