Download source file
Hi
I would like to know if is possible to retreive source file from Netlinx or Axlink controler?
    Only if it was loaded there in the first place. It's an option when the program is loaded whether you want to store the source file(s) or not. If the option is not selected, you can't retrieve it or reverse engineer it.
  • DenisDenis Posts: 163
    Thanks, but wich fuction in NS I have to use to check or download src file if it's exist?
  • PhreaKPhreaK Posts: 966
    Tools > File Transfer
    That'll bring up a dialogue with a couple of tabs up the top. Choose receive.
    From there hit 'Add...' and select 'NetLinx Source Code File'.
    Check out the 'Receiving Files from the Master Controller or System Device' in the NetLinx help for more info.
