Pioneer BDP-33FD control
Anyone successfully control one of these IP or RS-232? The web site has some documents listing available commands, and they explicitly say it's IP controllable, but there are no instructions whatsoever how to connect to it. After failing to get a web page or Telnet connection, I ran a port scan, and the only standard ports open are SMTP and POP3 ... and I find it hard to imagine you control it via e-mail
. Even if I have to resort to RS-232, there's nothing in there about baud rate, etc. I have an e-mail out to support, but figured I might get a quicker answer here.
Oh, and by the way, all indications are this box is really a re-packaged Sharp, and as such, has the irritating power saving thing going. Unless you turn on "Quick Start" in the setup menu, it won't accept IP commands when it's off.
Play
"'/A181AF39/RU',13"
Stop
"'/A181AF38/RU',13"
Pioneer's web site has a full listing of the commands (I was going to post a link, but couldn't find them when I went to check it, so I just attached the dang thing instead), so if anyone else is monkeying with this device, here are the sticking points for IP control:
1) It's port 8102 for control
2) There is a discrepancy in the doc for remote codes, it's "/<code>/RU" (the doc says just /R)
3) All commands terminate with a CR ($0D)
4) "Quick start" must be turned on in the menu or you lose the IP port when the power is off
I haven't tried RS-232 yet (and see no reason to really, the IP connection seems pretty robust), but I have to wonder if I didn't get that to work for the same reason the IP didn't work for me at first ... has to go directly out the port, typing it in won't work.
Not sure if its the same for the 33FD but in the 43FD manual there is a picture of the back of the unit showing the RS232 port. Its description is "RS-232C terminal. This port is not used."
The control documentation has some commands for it but I couldn't get it to work over serial, no way no how. The serial commands were very limited anyway so my guess is they are stopping support for 232 at some point and using IP only.
I have controlled the BDP-23FD units numerous times sucessfully with RS232.
When I first started working with these units, I discovered that I had to perform
a firmware upgrade on the deck in order to get the serial communication to work.
I now keep the FW disc with me in my CD case.
You basically download the file from Pioneer and burn it to a disc and then let
the deck read the file and update itself.
The entire process is thoroughly documented through Pioneer.
