Autopatch HDMI Matrix Switcher
                    We received our first Autopatch 8x8 HDMI Switcher today, and we were expecting the switcher to pass all audio/video that HDMI can carry.
However we discovered that the HDMI switcher does NOT pass HD Surround formats (For Example: Dolby TrueHD, DTS Master Audio). Nor Can it pass the 7.1 LPCM, or 5.1 LPCM formats. It only passes Standard Dolby Digital, and standard DTS.
Why?
There are a few other HDMI switchers on the market that all support these audio formats. I don't want to pull out a $300k AMX system and replace it with "the company that must not be named", but we might have to. Their HDMI switcher supports these formats.
Nearly EVERY bluray player on the market will output these audio formats. If you are installing a Home Theater with 7.1 or 5.1 Speaker layout you will want the nicer audio.
We can't use this, because our project has 4 home theaters and our client demands high resolution audio.
Disappointing.
Why?
Disappointing.
I just confirmed this a few days ago myself. HDMI was hard enough to implement. AMX has managed to make it impossible now. I myself am waiting to see if we see Blu-Ray and set top boxes with two HDMI outs, use one for video and one for audio. I haven't thought it all the way through but if true and it works could solve some problems.
Also note that the CTRON switch is double the AMX price, the SVNT switch is 4x the AMX price... but there are many choices that work with AMX.
Interesting comparisons:
https://spreadsheets.google.com/ccc?key=0AuEobFUk9H9UdHdVVlZLaDcwT0I0UEsycFdRYWJiX1E&hl=en#gid=0
discussion here
http://www.avsforum.com/avs-vb/showthread.php?t=1228283
Sorry for the tangent, I just feel that in 2010 we should have figured this out by now
HDMI is problematic, but the audio that you can get from it is worth the trouble(in my opinion). HDMI video is mostly dependent on the source material. In order to see a difference you need to have good source material.
We do use component switching most of the time, and try to stay away from HDMI switching when possible. However this client has need of both HDMI and component switchers. So we had hoped to use autopatch for both switchers, but are currently investigating other options.
During the installation my Co-workers noted that the AMX UTPro (an option on the HDMI 8x8 matrix switcher) has a better picture than the other cat 5 HDMI baluns that we were using. The AMX UTPro also seems to handle the distance much better, including 1080p60 at 200+ feet, which is something we were having a problem with on other baluns.
I may be upset with the "audio issues", but this unit is performing very well in the other respects.
AMX tech support says "check your sources".
I am working with Chad on this. AMX said tonight that it could be the cache in the UTP Pro. They said that it may have to do with the HDCP. I am not sure if that sounds right. I was wondering if anyone had to mess with any settings in the Surround Sound Receiver. Not only does the Receiver show that there is audio but it also shows "PCM". Can you make a receiver not receive "PCM"? The sources are HD Cable box, Apple TV and Sony 400Disc Changer. All appear to be set to Dolby Digital.
Installed one of these today and here is my findings re audio issues:
Samsung bluray - audio level very low and has to be set to pcm
Directv HR21 - seems to be working fine
Motorola DCT6214 III - display says 'unsupported audio format' and picture flashes on/off
Kaleidescape Kplayer 5000 - full digital distortion
AppleTV - works with Dolby Digital set to off
Mac Mini - high pitch whistle
picture works fine all all sources so it seems the audio is causing major compatibility issues. I wish there was a way to just turn the hdmi audio off to some outputs as I have analog feeds. better yet it just needs to work!
I'm going to have to work with one of these.
Thanks.
New firmware release doesnt appear to cover any of my issues with the product.
Now I'm scared!!
This is a very nice product at an almost reasonable price. AMX should find a way to make it work.
