sorting in Netlinx
Hello!
It´s a simple question:
Is there a "sorting" module or function to do "smart sorting" in NetLinx, like quicksort and so? Or should i implement a sorting algorithm by myself?
Thanks!
  • AMXJeffAMXJeff Posts: 450
    MorgoZ wrote: »
    Hello!
    Thanks!
    You will need to create your own sorting methods.
  • yuriyuri Posts: 861
    I have some samples I once got from somebody else... Can try to dig them up, thought it was a shellsort and a quicksort :)
    A shell sort is easier to implement, and for the kinds of lists I have had to deal with, efficient enough to go with. I suppose if the list was enormous, I would go with a quick sort, but otherwise the shell is good enough.
  • Jorde_VJorde_V Posts: 393
    jjames wrote: »
    Thanks for that link, a very interesting read.
  • MorgoZMorgoZ Posts: 116
    Thanks for your replys!!!
    The link of jjames was really helpfull, i´m finally using a Shell sort.
    Here is the code of the Shell sort, which is the same as the Spire_Jeff´s. But i think that it could be useful to post the raw code; just the Shell sort algorithm, since the code posted at the link is not easy to understand at first sight
    <code>
    DEFINE_CONSTANT
    //GAPS for Sedgewick sequence
    GAPS[] = {1968, 861, 336, 112, 48, 21, 7, 3, 1}
    volatile integer numFind, indGap, nTemp, length_GAPS
    length_GAPS = length_array(GAPS)
    /***** Shell Sort Algorithm ******/
    /*** for array A ***/
    numFind = length_array(A)
    indGap = 1
    while (GAPS[indGap] > numFind )
    indGap++
    while (indGap<= LENGTH_GAPS)
    k = GAPS[indGap]
    for (i=k+1; i<=numFind ; i++)
    j = i
    while (j > k && A[j-k] > A[j])
    nTemp = A[j]
    A[j] = A[j - k]
    A[j - k] = nTemp
    j = j-k;
    indGap++;
    </code>
    It can be also used for a string array.
    Salutes!!
    Sorry....... i didn´t know how to post the code inside a "code box"... if someone could help...
    Thanx!
  • AuserAuser Posts: 506
    MorgoZ wrote: »
    Thanx!
    You can wrap code in a [ code ] [ /code ] block like:
    var someCode
    Don't put spaces between the brackets and the code and /code tags. If you get stuck, hit "Reply With Quote" on this post and it should show you how it's formatted.
