MET-ECOM.
Hallo All.
Is available:
2 MET-ECOM
2 700Vi
4 5200i
The decision is required: one MET-ECOM sends a call on one 700Vi and two 5200i, the second MET-ECOM sends a call on the second 700Vi and others two 5200i.
Now the call from each panel MET-ECOM arrives on all TP simultaneously.
It is used AMX Intercom Interface V1.5.
    It sounds to me that you'll need to create 2 instances of the code. 1 for each group of TPs/MET-ECOM.
  • AlehaAleha Posts: 9
    vining wrote: »
    Can be will write a short example?
