Home AMX Technical Discussion
R3 Feedback
How would I send text the the LCD display on an R3 remote? Are there any settings in the remote that will need to be changed to do this? I was told by AMX that they had the ablility to, I just can't get it to work.
  • The R3 LCD is programmed in KeypadBuilder only - the text has one dynamic line at address 1
    ^TXT
    Assign a text string to those
    buttons with a defined
    address range
    Sets non-unicode text.
    Syntax:
    SEND_COMMAND <DEV>,"'^TXT-<vt addr range>,<new text>'"
    Variables:
    ? variable text address range = 1.
    ? button states range = 1 - 256 for multi-state buttons
    (0 = All states, for General buttons 1 = Off state and 2 = On state).
    ? new text = 1 - 50 ASCII characters.
    Example:
    SEND_COMMAND Keypad,"'^TXT-1,Test Only'"
    Sets the On and Off state text for the display.
  • An older thread, but this one had me scratching my head too. FINALLY realized in the manual that you have to send a ^FML command first. This has been working pretty good for me:
    SEND_COMMAND dvR3,"'^FML-1,D'"
    SEND_COMMAND dvR3,"'^TXT-1,Text Here'"
  • DavidRDavidR Posts: 62
    this worked for me once and then stopped... now I can't get the remote back to defaults when it displays the text programmed by keypadbuilder. any ideas?
    DavidR wrote: »
    Well, perhaps you could put text commands in the data_event>online: section that populate it with the default text you want.
