So Windows 7 x64......
It's interesting that some things seem to work fine and others don't with my new Windows 7 64-bit environment.
So far I've discovered that no matter how hard I try, NS3 will not connect RS-232 to any NetLinx master. I am using a Trendnet TU-S9 USB to Serial adapter that works fine with other software and 4 different terminal programs, just not NS3 or the terminal program contained therein.
AMX USBLan does not work either. Even when run and installed in "XP compatibility mode". When I plug in a TP via USB the driver can never be found.
Also I'm missing Fonts in TPDesign4, although they are installed on my computer, I can pull up their names in TPD, I just cant get the buttons to display the characters.
This is all I've discovered so far, but I've had the computer less than a week.
Any ideas? If anyone else has experience with this, any help would be appreciated.
Thank you.
    jjamesjjames Posts: 2,908
    Things that make you go hmm?
    Very interesting. I've been running Win 7 x64 for almost a year now and haven't seen any of those problems.
    What kind of computer is it? Computers are strange things, much like cars: YMMV.
    feddxfeddx Posts: 175
    It's a DELL Precision M6500. I've verified all of the problems are specific to the laptop as I just used my old XP Dell Latitude D820 to do all of the things the new one won't.
    The USBLan and terminal things seem like they should be easy fixes.
    I believe you have to adjust the firewall for the USBLan to work. I can't comment on the USB to serial device though - I had a heck of a time getting my IOGear to work. Took a couple of hours of uninstalling, reinstalling, etc. to finally get it work.
    For the USB to Serial, the hardware and drivers work for every other terminal software I use on that computer and with ClearOne Converge Console, Polycom Sound Structure Studio, and I can connect to any master with any terminal program except the NS one.
    I also can use it on my Latitude Laptop and connect in NS3 and it's terminal. There's something specific to how the NS3 works in the Windows 7 Laptop and the Trendnet device.
    the8thstthe8thst Posts: 470
    You have to enter an exception into the windows firewall to all USBLan to work with "Public" networks.
    Jorde_VJorde_V Posts: 393
    the8thst wrote: »
    Are you sure about that? It's supposed to create a new connection which it can't do on windows 7 x64.
    I encountered the exact issues the OP described with several laptops all running windows 7 x64, that has led me to the conclusion that it just won't run well on windows 7 x64, for that reason I have an XP partition as well (32-bit).
    It might be different on windows 7 x86, but on x64 it doesn't run.
    Nerieru wrote: »
    That was the fix that I had to have my installers do on their field laptops that are running Win 7 x64. After adding the exception they have been able to download to R4 remotes without issue.
    I had to do the same thing on my laptop and my two desktop systems which are running Win 7 x32.
    The OP mentioned problems creating the connection and not problems installing, so I assumed it was the firewall blocking the connection for him like it did with my installers' laptops.
    *** edit - I just re-read the original post and I see that the OP is talking about touch panels not connecting via USB. I have not tried to connect a touch panel USB to my installers' laptops, so there may be an issue there. I know the installers are able to download to R4s though.
    the8thst wrote: »
    Not sure about R4s but I am positive that I can't do it to TPs I use my windows xp partition mostly for AMX these days so I don't even bother with the windows 7 x64 when doing AMX development.
    Problems installing are fixable by doing it in compatibility mode/run as admin.
    Windows Compatibility
    Any hint or official word when the AMX suite will be officially compatible with any current version of Windows? I heard Windows 8 was on the horizon...would be funny if AMX accomplishes Vista compatibility when 8 drops.
    roognation wrote: »
    You are funny. You should quit your day job and take up standup.
    I did notice there was an upgrade to Panel Preview, which in the release notes they specify the capability of running it on Win7. I'm thinking you'll see more of that.
    Installing IR Edit not working for me.
    Win 7 Home Edition Premium 64 bits
    I have an error message about XP SP1 is needed.
    You may have already done these things, but just to post them in case you didn't...
    1) make sure you run the installer from your computer and not from a shared drive. For example put the installer file(s) on your desktop and run them from there.
    2) Make sure you right click on the installer file, got to properties, then the compatibility tab and set it for Win XP SP3 mode.
    3) Depending upon your situation you may also want to 'Run As Administrator."
    4) If the install fails, make sure to 'uninstall' it before trying again with different settings.
    A lot of it seems to be trial and error depending upon so many things. Keep messing with the compatiblility mode until you choose the right one.
    One last thing. Turn off all firewalls prior to installation. A lot of the WIN 7 firewall blocks happen without notification to you. So, as far as you know, it went without any blocks. But, If you look at the Windows event log you see that the firewall pretty much blocked half the files the installer tried to write.
    Hope that helps.
    Thanks a lot Eric, it's working now.
    I'm new with Win 7 and didn't know the compatibility trick...
    Any solution for Visual Architect?
    An error occured about SQL Server 2005 Express.
    If I install SQL Server 2005 Express 64 bits from MS first, can I install VA with the CD?
    Yes.
    1) Uninstall VA.
    2) Install Netlinx Studio 3 (if not already installed.)
    3) Use Netlinx Studio 3 for all programming needs.
    4) Dispose of Visual Architect install disc.
    jjames wrote: »
    Yes.
    1) Uninstall VA.
    I notice you skip the 'set VA disc on fire' step. I usually have to do this around here.
    I have a M6400 running Win7 Pro. I use a Quatech Express card for serial control and have not experienced any issues. I have tried to avoid USB to Serial devices since the first time I tried to connect to a Gentner with one.
    BylLeetBylLeet Posts: 1
    IREdit and IRIS unit
    I installed IREDIT on my mork computer which is running Win7 32 bit. It worked ok unitl I tried to capture a remote with the IRIS unit. The computer 'blue screen' ed me. I could not get it to work, so I took the remote home and hooked up to my XP laptop.
    Does anybody know if this can be fixed/worked around? I really don't want to have to carry 2 laptops around
    BylLeet wrote: »
    Don't you do your code capturing beforehand? It's what I do here and that saves me the trouble of having to carry multiple laptops, or a large bulk of equipment for that matter.
    dominiondominion Posts: 9
    IR Edit is working on my Windows 7 Home Premium.
    Did following steps
    a) Checked if Windows Firewall is allowing all AMX applications
    b) Changed "IREditSetup.exe" compatibility mode to Windows XP Service Pack2
    c) Changed "IREditSystemFiles.exe" compatability to Windows XP Service Pack 2
    d) Installed the larger size "IREditSystemFiles.exe" file (36MB)
    e) Then Installed "IREditSetup.exe"file (5.38MB)
    Now it works fine.
    I have found it impossible to create a new IR file with IREdit on my Win7 32 laptop. It works until you try to capture something, then it crashes ... I don't get a blue screen, but I can't go on either. However, if I copy an existing IR file and just overwrite the codes, that works just fine. I've gotten so much in the habit of it, I don't even think twice about it anymore. I just grab an IR file of a similar device, copy and rename it, then go in and edit everything. Working from an existing file, I can copy, paste, delete codes, make new ones, etc. But start from scratch and it goes down in flames.
    Have you tried running IREdit as administrator via right-clicking on the icon, going to properties, then comparability? It should be at the bottom of that tab.
