Home AMX Technical Discussion
IRL file for KAON K275 HD Receiver
Hi ,
Orbit Showtime Network (OSN) in the Middle east has recently made it mandatory to use their HD receivers.
They are the KAON K275 Models. Now the client is behind us to modify the AMX to suit the new receivers.
I searched frantically for the IRL files, but not been able to retrieve the same.
By any chance, if anyone has the same, could you please send it to me.
Thanks in advance,
Rejoice.
  • Try this...
  • RC6 to Raw format
    Thanks for the file, Thomas. I shall try it out.
    Meanwhile, I have got the OSN keychart from KAON 275. But it is not in the hexkeyformat
    that is required by AMX IREdit. Below is the sample table:
    Key# SIO Specific labels Dec data RC6-6ACustomer ID (Long):86 System code 39 XMP Registry 17508 (4464h)
    1 Ch List 014 2A
    2 TV Power --- ----
    3 STB Power 012 0F
    4 1 001 01
    5 2 002 02
    Any ideas on how can i convert it to AMX Hex format.
    Rijo.
  • IR File retreived Successfully
    I finally managed to get the IR files learned through an AMX IRIS.
    The codes are working perfectly.
    If anyone wants to use it in future, I have attached the file.
    Thanks for all your support.
