Yes and no. There is no built-in format for it, but you can always enter carriage returns between letters to fake it (Ctrl-Enter). Awkward and kludgy, but it will work in a pinch if you aren't trying to get too fancy. Now if you want the whole thing sideways, like it was spun 90 degrees, you'll have to turn your text into an image and put it on the element that way.
So yes, you can do it. But no on a quick, easy, elegant built-in method.
If you send text to a button with a bar character (| which is shift-\ on a typical US keyboard) the panel will treat the bar character as a carriage return when it renders. So, SEND_COMMAND TP, "'^TXT-1,0,A|B|C|D'" will give you a vertical ABCD.
I really wish TP4 could rotate objects. Its hard to exactly reproduce the built in text effects and rotated text inevitably winds up looking just slightly different from all the other text on the panel as a result.
Yep, I'm familiar with that term, but I always thought of that usage as an operator, not necessarily the name of the character. So I looked it up ... the proper name of the glyph itself is "vertical bar" if it's one solid line, and "broken bar" if it's the kind that has a small space in the middle. Might as well just call the key that produces it a pipe though, since the type of glyph it produces depends on the font..
Then things would look very pixelated. It isn't trivial to rotate a square on a pixel based screen and still have it have straight edges. Better to do it in a software program that has the ability to do it well and then use the resulting image.
but i want to send text from system..... :-(
john
i think it's better i rotate my iphone...
thanks
john
we (old unix people) call that character a 'pipe'
Its a great information, thanks a lot.
