NXR-ZGW Requiring Reboots
TurnipTruck
in AMX Hardware
Greetings,
I just updated an R4 and ZGW from version 1.xx to the latest V3. I followed the update procedures as directed and all went well. The R4 and gateway are communicating on the latest firmware.
However, now the R4 will lose communication with the system occasionally. A reboot of the gateway will bring it back until next time.
I am quite sure that the problem is with the gateway as I cannot get to its webpage once the fault happens.
Any ideas? Thanks.
Gateway Firmware is 3.01.11
Gateway Zigbee Firmware is 3.01.06
Remote Firmware Version is 3.01.05
Remote Zigbee Version is 3.01.05
Any ideas? Thanks.
Does the unit hook up again if the DHCP Server comes back online? There are many enterprise level switches that take longer than 30 seconds to come to life.
Either way, that is not the problem in this case, since the gateways are set to static.
I do run all mine Static. so, I guess it's not an issue. But, I was just curious. Thanx!
e
I don't know. Looking into it.
Thanks. I have another gateway that I could swap to test. The site is quite a distance, so I won't be able to do it immediately.
I've got a situation that sounds similar - a NXR-ZGW (3.01.07) with a static IP that requires reboots 1 - 2 times per week.
TurnipTruck: Were you able to resolve the reboot problem you had?
Rich Abel
No any solution on this problem? I have exactly the same problem with the last firmware as well. Gateway has static IP, according all recomendation it is on channel 26 and power supply (not PoE) through UPS.
It happens randomly. The gateway was replaced once and worked good for a couple of the months and recently it happend again. When it locks, I could not even login through webinterface and it is not in device tree.
Any ideas, please.
http://www.dataprobe.com/iboot-g2.php
PM if you need one.
It would be cheaper to run the power to the gateway through a relay on the AMX master. Then let the master document the offline event and reboot the gateway automagically.
PS. Is the gateway an NXR-ZGW or NXR-ZGW-PRO? My problem was with horrible signal range from an NXR-ZGW and AMX had me swap it for the newer NXR-ZGW-PRO and things have been rock solid ever since. The Pro version has ALOT better signal range and it seemed to respond faster in the web browser too (maybe more memory or better hardware?).
I wonder why there is so little debugging available with these devices. In the settings there is something called debug mode but I don't know if it actually does anything. When problems start to happen there isn't much to go on unless its obvious like buffer overflows and the like. It would be nice to be able to log what's its doing so that anything that happened right before it went offline could be logged and examined. This would likely have been helpful when it was discovered that all the gateways go offline when a time server action happens.
We still have the R4's / Gateways falling offline as a result of the Clock Manager setting time which I would have hoped to have been fixed by now. I reduced my update cylce to every 4 hours to reduce the frequency that these fall offline but it still needs fixin'. Another odd thing I've notice is that this only occurs on 1 gateway, the one on channel 25 so is this a coincidence that the one that doesn't lock up is the one the clock manager causes to drop offline while the one that does lock doesn't fall online due to the clock manager. Very scewry.
Here's what's printed in my log every 4 hours when the clock manager does it's thing. Gateway is dev 20002/IP 192.168.9.129 and the associated R4's DEVs are 10023 & 10024.
