Moxi Cable Box
jjames
                    Just thought I'd be nice and save someone from ripping their hair out like I have for the past two days.
A couple of years ago I sent in a Moxi box to AMX to toy around with and learn the commands from it since we couldn't get it working. Well, since then Moxi seems to have updated their hardware. I'm not entirely sure of the model number, but it's from Charter. I'm wrapping up a job right now that has a newer box and again, I couldn't control it using any existing IR files or hex commands (tried some from remotecentral and some hex codes from the RTI IR library.)
So yesterday I brought my IRIS on-site and tried learning it. I kept getting an "ER"ror when verifying. Well, I finally figured out that it had a toggle bit in the IR protocol it uses (RC6.) So, after several hours (due to Win7 not liking my IOGear USB to Serial adapter and looking for updated drivers that would work) of trying to learn in the remote, I finally got it all in (both command sets.) Attached is the IR file.
There are two command sets ("A" and "B"); in order to use the file properly you'll need to manage the toggle in code. I did this every time I send a command now:
I had to modify my channel macro, toggling it every time a number went out. (Oh the advantages of using custom code instead of the built-in XCH!!!) Anyway - also attached is a description of the RC6 IR protocol.
Hopefully this helps someone not go bald!
nMOXI_TOGGLE = !nMOXI_TOGGLE TO[dvMOXI,BUTTON.INPUT.CHANNEL + (nMOXI_TOGGLE * 100)]
J, thanks for posting this info here. I have a job next week with 3 Moxi boxes and this could have ruined my week!
In the end, is your control of the Moxi reliable? End user is none the wiser to what you are doing behind the scenes?
Anyway, I think we're talking about two different beasts; perhaps the Marantz is a little more forgiving - who knows! If you look over the description of RC6 it talks about this a little bit more in detail.
Unfortunately, this is the only time I've ever spent with a Moxi box (and even a few weeks afterwards, there was talk of getting rid of it - go figure!), so I really hated having spent so much time chasing this one down, but at least I learned something.
Thanks again J, you definitely saved me on that one!
