Anyone Know How to Stop TPD4 from Crashing?
TurnipTruck
Running Windows XP SP3 with the latest version of TPD4. It crashes almost every time I try to connect to the master to upload panel files.
TS had me remove the program and its registry entries then reinstall. Worked better for a short time then same thing.
I habitually disconnect after a transfer as that seemed to have helped in the past.
Thanks for any suggestions.
This has been an issue for so long that I'm beginning to think that it only happens in PCs not residing in Texas.
Well, not that this suggestion is a 'little thing.' But, I have found that my AMX software seems to run a little better under Win7. Perhaps it's time to look at moving to last year's OS.
Open TPD4, create a new panel file, close it. Don't worry about saving it. Open your original panel file and try transferring - it'll probably not crash this time.
I do seem to remember TPD4 crashing more under XP for some reason.
I'm sort of numb to it now and it doesn't bother me as much as NS3 crashing which happens more frequently than TPD4. I think that's mostly due to having 2 instances of NS3 open at the same time with both running diagnostics & debug viewing somewhat large structures while having numerous files open.
If anyone doesn't know where Auto-save is, it's under Preferences -> Workspace.
