Touch Panel Keyboard Strings from port other than 1
I have a module that listens for text from a keyboard to be sent to it as a string. In order to fit their panel files into my usual panel, I switched all channel, address, level, command, etc ports to 10 because I am already using port 1 for other things. The issue I have is getting the "KEYB-XXX" strings from the keyboard which are always sent from port 1 of the touch panel devices to send to the module which is listening on touch panel port 10.
My first though was to create a data event on the touch panel port 1 and then redirect them as if they are from port 10 similar to doing a do_push. But, I cant find a way of emulating the "KEYB-XXX" string as if it came from port 10.
Has anyone else had this issue or know of a fix for my problem?
    wilw410 wrote: »
    I haven't used the built-in keyboard/keypad for years. I personally make my own keyboard that doesn't rely upon strings from the touch panel. That way a keyboard/pad can be anything I want and doesn't rely upon a preset, hard-coded solution.
    that's what I'd do if I were you.
    e
    a_riot42a_riot42 Posts: 1,624
    ericmedley wrote: »
    e
    I use the built in keyboard with good success. It has all the shifted characters as well and I didn't want to have to do all the work required to build that. Its a better solution in the long run I agree, but I can't get myself to do it when something that already works exist. Basic laziness.
    For your module, can't you just create a data_event that listens for the keyb- command on port 1?
    I was able to solve it by sending two touch panel arrays into the module, one port 1 and one port 11. Then I cretaed the DATA_EVENT using the port 1 array and everything else the port 11 array.
    Is there a solution if it was a compiled module where I do not have the actual code and cannot modify it? I often use modules from AMX or other sources that are compiled already as jars or tkos.
    I guess I am looking for a new command like DO_PUSH that is DO_STRING or DO_COMMAND to emulate touch panel activity in code when needed. Feature request?
    It's not really an "issue," it's the way they are made. Panel strings just come from port 1, and that is all there is to it. I generally make a device internal to my module that I dynamically populate on start up. Say the panel you send to your module for buttons and feedback uses a parameter variable called dvPanel, and your internal device that you want to parse feedback from is named dvMsgPanel. Then you put these lines in DEFINE_START:
    dvMsgPanel.NUMBER = dvPanel.NUMBER ;
    dvMsgPanel.PORT = 1 ;
    dvMsgPanels.SYSTEM = dvPanel.SYSTEM ;
    REBUILD_EVENT() ; // put this at the end of the section in case other stuff needs it
    Now you have a device equal to whatever your passed panel is, but on port 1. I make it a point to make certain my text field sends something unique, so I know it's my module generating the data and no someone else's.
    If you have a compiled module from another party that is using anything but port 1 for this, it's not going to work no matter what you do.
    DHawthorne wrote: »
    That's a good trick, I might just have to rebuild the one module I've got with this issue to take advantage of it. :)
