RS232 DA
Hi,
I am looking for a solution to controlling several projectors(all the same type) at the same time using rs232 . Is there a RS232 D.A. on the market or RS232 over cat5 D.A. that could be used?
this will provide an RS232 connection to a device and then pass it over IP.
It works quite well.
e
You should have no problem communicating to multiple projectors, but getting them to talk back to your control system through the DA device will present a challenge.
Instead of the Digi One though you might consider the SitePlayer serial to IP adapter that Hedberg has posted about since they are less that 1/2 the price of a Digi One. $180.00 vs $80.00 (w/ POE ability & local Power Supply).
Link:
http://netmedia.com/siteplayer/telnet/sptpoe.html
I just ordered a few last night but other forum members have used these for a while and I haven't heard anything negative about them. I know the Digi products are rock solid as are Moxa and others but I'm sure if the SitePlayer wasn't equally as reliable we would have heard. I actually went through the forum posts last night prior to ordering these just to see what was said and it was all good.
Plus going this route still provides you the abiltiy to control the projectors individually if you desire. IMHO this is probably the cheapest and best way to go. An $80.00 upgrade per projector should fit into any budget if you don't have the physical serial ports on the master to do what you need.
Blackbox do a 3 and 8 port unit - not cheap - code is DBU-232 & 2328
Cheers
Most useful.
