Reboot master from code
I've searched several times and I can't find the answer.
What code can I use to reboot the master from within the program? I know.. bad idea, etc. , but I need a temporary fix for a problem that's happening at a site 3 hours away.
  • HedbergHedberg Posts: 671
    reboot(0)
    or
    reboot(0:1:0)
    Check out the Netlinx Studio online help.
  • BigsquatchBigsquatch Posts: 216
    Sent to which device?
    Trying this from "Control a Device' does not work.
    SEND_COMMAND 0:1:1, "'REBOOT (0:1:0)'"
    SEND_COMMAND 0:1:1, "'REBOOT (0:1:1)'"
    SEND_COMMAND 0:1:1, "'REBOOT (0)'"
    No luck with any of them.
    it's a function, not a string to be sent. For example:
    if(snafu)
      snafu = 0
      reboot(0:1:0)
    Hedberg wrote: »
    if(snafu)
      snafu = 0
      reboot(0:1:0)
    Ok, thank you!
  • PhreaKPhreaK Posts: 966
    Alternatively if you are just using it for some troubleshooting you can telnet/ssh into the box and issue a reboot i]<device number>[/i command.
    PhreaK wrote: »
    Right. But there are some network issues there (another company is in charge of the network there) and when there are problems I can't telnet to the master, only ping works.
  • Bigsquatch wrote: »
    Is this a older NIxxxx?
    John
    John_Glove wrote: »
    John
    Yes, it's a NI3000 installed at least 3 years ago. Maybe 4 or 5 years old. Why do you ask?
    Please read:
    http://www.amxforums.com/showthread.php?7903-Network-Probs-since-change-switch
    there are some network problems with older NI's.
    john
