Reboot master from code
I've searched several times and I can't find the answer.
What code can I use to reboot the master from within the program? I know.. bad idea, etc. , but I need a temporary fix for a problem that's happening at a site 3 hours away.
or
reboot(0:1:0)
Check out the Netlinx Studio online help.
Trying this from "Control a Device' does not work.
SEND_COMMAND 0:1:1, "'REBOOT (0:1:0)'"
SEND_COMMAND 0:1:1, "'REBOOT (0:1:1)'"
SEND_COMMAND 0:1:1, "'REBOOT (0)'"
No luck with any of them.
Ok, thank you!
Right. But there are some network issues there (another company is in charge of the network there) and when there are problems I can't telnet to the master, only ping works.
Is this a older NIxxxx?
John
Yes, it's a NI3000 installed at least 3 years ago. Maybe 4 or 5 years old. Why do you ask?
Please read:
http://www.amxforums.com/showthread.php?7903-Network-Probs-since-change-switch
there are some network problems with older NI's.
john
