display value on bargraph problem
I am trying to do a module for denon 3310 AVR but I am having some problems with the volume description. (Files are added)
When I press the volume up button the volume on the receiver is raise up but on the bargraph it always set to 0. And when I am trying to drug the bar he doesn’t move he is always returning to zero. (Same in volume down)
In the diagnostic I see the value raising but the value always return to zero.
Line 30 (16:13:25):: Command To [33001:1:1]-[MAIN_VOLUME+]
Line 31 (16:13:25):: Command From [33001:1:1]-[MAIN_VOLUME+]
Line 32 (16:13:25):: String To [5001:1:1]-[MVUP#13]
Line 33 (16:13:25):: Input Status: Released [11001:14:1] - Channel 24
Line 34 (16:13:25):: String From [5001:1:1]-[MV965#13MVMAX 975#13]
Line 35 (16:13:25):: String To [33001:1:1]-[MAIN_VOLUME=96#13]
Line 36 (16:13:25):: String From [33001:1:1]-[MAIN_VOLUME=96#13]
Line 37 (16:13:25):: String To [33001:1:1]-[MAIN_VOLUME=0#13]
Line 38 (16:13:25):: String From [33001:1:1]-[MAIN_VOLUME=0#13]
Line 39 (16:13:25):: Level Value To [11001:14:1] - Level 1 Value= 96
Line 40 (16:13:25):: Level Value To [11001:14:1] - Level 1 Value= 0
Line 41 (16:13:25):: String To [33001:1:1]-[MAIN_VOLUME_SET=96#13]
Line 42 (16:13:25):: String From [33001:1:1]-[MAIN_VOLUME_SET=96#13]
Line 43 (16:13:25):: String To [33001:1:1]-[MAIN_VOLUME_SET=0#13]
Line 44 (16:13:25):: String From [33001:1:1]-[MAIN_VOLUME_SET=0#13]
I don’t understand what is the problem. I want to show the value on the bar but it is always on zero.
What can be the problem?
Thanks for any help.
I guess that's what paul jujst said. I really nead to read posts first.
thanks the MVMAX was the problem.
But know I have another problem I am trying to use the dragging of the bar to change the volume on the AVR but when I am dragging it the volume get crazy.
In the UI FILE:
I think the problem is in the command: send_level dvTP_RCV,1,nVOLUME in the DEFINE_PROGRAM section.
Because when I am changing the volume value with the bar in the DATA_EAVENT
DATA_EVENT[vdvReceiver]
ACTIVE(LEFT_STRING(DATA.TEXT,12)=='MAIN_VOLUME='):// VOLUME FEEDBACK
nVOLUME=ATOI(DATA.TEXT)
SEND_STRING 0,"'From UI RECEIVED FROM COMM MainVol: ',itoa(nVOLUME)"
The nVOLUME is change and then he send the value again to the TP I think.
I want to get feedback from the receiver and send the value to the bargraph and also to control the volume with the bar and the up and down buttons.
How can I do that?????
Thanks for any help
Can someone answer me please I'm pretty stuck with this??
This was also just discussed very recently in another thread so if you feel like searching......
