How do I put a ' (apostrophe) inside a string of text?
I can't believe I have never run into this before, but how do you create a string of text that has an apostrophe within the string?
I am trying to send text (using constants to store the text) to an LED readerboard and think I remember there being a special character sequence that allows that.
    Kmclane wrote: »
    You can't.
    Just kidding. Its its own escape character, similar to back slashes in other languages. Type the apostrophe twice to make it nice.
  • KmclaneKmclane Posts: 33
    Thanks!
    Digging feverishly through all of my old manuals and guides and couldn't (or should I say ouldn''t) find anything.
    I suspected that was the solution, but then thought it would interpret as two text segments, right next to each other. Don't know why I just didn't compile and test.
  • ColzieColzie Posts: 470
    Wow, thanks Paul! I always used hex 27, but your way is much cleaner.
    "'Ben', $27, 's Rm'"
    "'Ben''s Rm'"
    Colzie wrote: »
    "'Ben''s Rm'"
    Ha! I did this same thing too up until about 3 years ago. I still run into old code where I found I did this.
    Colzie wrote: »
    "'Ben''s Rm'"
    I haven't seen the escape characters documented anywhere, so we are left to our own devices. I'm sure this stumps everyone the first time.
  • GSLogicGSLogic Posts: 562
    Just to be a smart but - I've always used:
    "'Ben', 39, 's Rm'"
    You can also use this for temp degrees °
    There's Gary again - always wanting to be different! :D
    I do the double apostrophe as well.
