IR/Serial
This seem a rookie question, but how do you set up an IR/Serial port to be used as serial (trasmit only) instead of IR? Need this function because an ni3100 has run out of serial ports. My current code (to test the system) looks like this:
//dvNI700 = 5001:0:0
dvIR = 05001:3:0 //IR port out
dvTOUCHPANEL = 3201:1:0 //TOUCH PANEL
data_event[dvIR]
online:
SEND_COMMAND dvIR,"'SET MODE SERIAL'"
SEND_COMMAND dvIR,"'CAROFF'"
SEND_COMMAND dvIR,"'SET BAUD 9600,N,8,1 485 DISABLE'"
button_event[dvTOUCHPANEL,1]
push:
send_string dvIR,"$01"
Is there anything fundamental or otherwise that would be causing a problem with this?
*firmware is up to date
*tested on an ni700 (destined for an ni3100)
data_event[dvIR]
online:
push:
We've had to do the IR/serial thing with some tiny little Extron media link audio switchers and have had perfect results so far. They are 9600 baud and less than 10', to be sure. I'd rather use normal serial ports too, but the Extron stuff seems to work fine.
Umm, IRS4? Who mentioned an IRS4? Not sure the OP was after a comparison of other solutions, he just seems to want to use existing hardware (onboard IR ports as far as I can tell) to solve a problem. As such his solution is cheaper for the client than an IP-RS232 adaptor too.
While using IR ports as one way serial is definitely not best practice, it's perfectly adequate in many scenarios where devices need to be added to existing installs, or where a client's budget doesn't lend itself to a more elegant solution.
IR ports are only valuable for IR transmission if they are needed to control devices via IR; if not they're redundant hardware that's begging to be used.
For the record, I've never had any dramas controlling devices via one way serial off an IR port (remembering the limitations already noted by other posters). IP-RS232 devices are far less reliable as the Ethernet network between the NetLinx and peripheral device introduces multiple points of failure.
Thanks.
Axcent 2, no.
Axcent 3 (Pro), yes.
See Tech Note 394 for more info.
I have just run into an interesting limitation while testing an IR port for 1-way rs232 use. The data string seems to be limited to 64 characters in length. Sending a message with 65 characters turns the string into random garbage.
Tested by routing the output of the IR port into an empty rs-232 port.
Has anyone seen documentation that supports this?
The 64 character limit sounds right. Check out TN 156.
You’ll need to break up your data into 64 character chunks and do multiple send_strings.
