Sqeezebox Touch
Hey all,
I'm looking at doing a system with a Squeezebox Touch in it. The person who's bidding the system is on this forum, So, I'm not talking behind their back or anything.
I've done some Squeezebox systems but not the Touch. Any issues with the AMX module that's out there that anyone knows about, or for that matter the box itself.
Any info would be helpful.
e
e
They did a few revisions on firmware/software which might mess it up. But that should go for all the units. What's not in the module in any case is Internet Radio. And that is one of the key-features of it.
If they want a host for the server then I'd recommend the VortexBox, 1 or 2 TB with audio out and a rip tray. It will also rip DVDs in MKV and mirror to MPEG4 if you choose to stream to any number of available MKV or MPEG4players. It's a Linux computer runnig fc14 for around $500.00.
Eeek. that might be a bad thing in that I think that it's one of the primary desires for having it.
Vinning: I think they are using a NAS for a server. (At least that's what I read.) Squeezebox is one of those things I'm just not sure will last in the long-haul. But, what in our industry DOES last in the long haul????
Thanks for the info guys. I think I have some info to go back and ask questions now.
e
We frequently had it working great with full 2-way control and art and all. Til we gave up having to revisit every install every couple months. The customer doesn't understand why it's broken, just that you seem to be here a lot fixing it. Free. Another case of doing the customer a favor with a cheap product causing a lot of extra unpaid work and a mad customer. Nope.
Two good choices: Autonomic Controls Mirage, AudioRequest. Both do streaming well, with good stable integrator support. Well, Request has gotten sloppy and not added specific external commands for the new streaming additions the way you can to everything else that came before. So you can get to the category discretely, but it won't let you, say, jump directly to a specific Pandora "station". And they will tell you they have no intention of adding such. It's not the same company it used to be.
Note that these products only cost more until your first service call on the cheap ones. And you can decide what price you put on a customer whose system just keeps working.
If you give a customer a Vortexbox running Squeezebox, don't tell then there's gui and they won't screw things up. I agree that dealing with this box in particular is PITA but that's only cuz I'm always screwing it up. Changing the shell and perl scripts and doing other abnormal things to the boxes but that's another cool feature of the box since the open linux OS allows me to do this. If I leave the boxes alone they cause me no grief and a box that rips CDs and is evolving as a DVD ripper with line level audio out that downloads cover art, etc is a good deal and extremely reliable if you don't F' with it. You really can't F' with those other boxes.
If it were that simple... The Squeezebox manages its own updates, you have no choice when or if.
I really don't like fixing things I didn't break.
I love the open source community and all that. But, I think they don't seem to understand the concept of 'A camel is a horse that was designed by a committee.'
Sometimes conformity is a good thing.
I will say all my experiences with the Squeezebox have been not-so-good. But, I don't have tons of experience with it. I covet all the opinions. thanks for sharing!
e
Very few things force you to perform "auto" updates unless you choose too. If this is set "not to check" does it still check despite the setting or is this possibly just for checking "plugins" software?
I think it's interesting when we went through the hardening process for our HCS how Windows seems to handle turning updates off. It seems simple enough when you first do it, but then the OS goes into this annoying 'You've got your updates turned off, I'll turn them on for you because you obviously want them on, don't you?" mode. So, not only did we have to turn off updates but also the annoy-ware associated with turning it off.
But, back to the thread subject...
Does anyone know of any other ways to get Rhapsody on a box that is controllable via RS232 or IP? I've found a few A/V receivers that have it built-in. Marantz, Sony, etc.. I even think marantz has a stand-alone media box for just such things. There are quite a few MP3 players that'll do Rhapsody but they're mostly IR controlled or front panel.
Yes, you would think that it would stop the updates. It was not available before, and appears not to do so reliably now. I'm set for no updates and 4 days ago got an update. My comments stand not as how things are stated to be, only as we have found them to be in our experience.
I hope they get better at this all. Our experience before was too painful. The updates that change the protocol between the boxes and the service on the internet must be done, as the old protocols were always turned off after the new ones when into effect. So if you had a way to prevent the update, no problem unless you wanted it to work.
Autonomics Mirage, by June per everyone we've talked to.
The difference is that there's a company in charge at Autonomic, and they have always been all about integration. They understand that their product will be wrought into larger projects and code will expect specific response. Sure, things will change across time, but a savvy group like Autonomic knows we need the stability of deprecated command sets even after major updates, or we are dead.
There's a shifting committee running Squeeze that's really not interested in integrators... they are about the feature of the moment. Cool, but not suitable for our practical use.
They are completely focused on their own devices and they don't expect those devices to be controlled from anything other than their own devices. Which is totally fine for the market they are targeting, but this also means it has little value for us integrators.
I would also advise the mirage media server as Autonomic has been good when it comes to their modules and products.
