9000i Left side hardbutton graphic disable?
livewiresi
Is there a way through code or setup to disable to "pop out" graphic?
Through setup i disabled them...and it disabled functionality ie: i couldn't get into setup via button press, however the graphic "pop out" was still active even when disabled.
Actually on the only 9000i I've done the dealer requested that I disable the external buttons buttons altogether. The capacitive (or whatever it is) buttons don't function as reliable as a traditional "hard" button, and the navigation side is useless since it is completely flat. What is the point of external buttons if you have to look down to see where you are touching?
