TCP Communications - Newbie needs help =)
Hi there,
I am new to the community and have only recently completed my lvl 1 programming course. I am getting there slowly
but have stumbled across the possibility of communicating to equipment via IP and have been battling to get it to work.
I have read through the forums and tried various different solutions including modifying modules and other code on the
the forum but just cant seem to get it to work..
Basically I have an Onkyo TX-NR609 av receiver which is enabled to be network controlled via TCP port 60128. I have
statically setup the amp on 192.168.0.34 on the network.
Using Hercules (a TCP client software), I can send the following hex strings to switch the amp on and off;
On:
49534350000000100000000801000000213150575230310d0a
Off:
49534350000000100000000801000000213150575230300d0a
I currently have the following in my main source file;
dvOnkyo = 0:5:0
dvTP = 10001:1:0
DEFINE_CONSTANT
hostIpAddress = '192.168.0.34'
hostPort = 60128
nOnkyoConnected = 0
data_event[dvOnkyo]
online:
nOnkyoConnected = 1
offline:
nOnkyoConnected = 0
ip_client_open(dvOnkyo.port,hostIpAddress,hostPort,IP_TCP)
BUTTON_EVENT[dvTP,1] // power on
SEND_STRING dvOnkyo,"$49,$53,$43,$50,$00,$00,$00,$10,$00,$00,$00,$08,$01,$00,$00,$00,$21,$31,$50,$57,$52,$30,$31,$0d,$0a";
BUTTON_EVENT[dvTP,2] // power off
SEND_STRING dvOnkyo,"$49,$53,$43,$50,$00,$00,$00,$10,$00,$00,$00,$08,$01,$00,$00,$00,$21,$31,$50,$57,$52,$30,$30,$0d,$0a";
Monitoring the Netlinx internal diagnostics shows the following;
Line 1 (23:06:29):: CIpEvent::OnLine 10001:1:1
Line 2 (23:06:29):: SendString to socket-local port (5) invalid
Line 3 (23:06:29):: CIpEvent::OnError 0:5:1
// This is after pressing button 1
Line 4 (23:06:31):: SendString to socket-local port (5) invalid
Line 5 (23:06:31):: CIpEvent::OnError 0:5:1
//This is after pressing button 2
Can you guys see where I am going wrong? I have honestly tried looking everywhere
but just cannot figure it out and its driving me crazy !!
Thanks in advance,
Mike
    Where are you opening the port? Copy the IP_Client_Open line that you have in the OFFLINE handler and stick it in define_start. Now when the code initiates define_start will run and you'll open the socket and generate an online event and then if the socket closes your offline event will re-open it. In time you can change this to be a little more elegant but for now that should get you working.
  • mkleynhansmkleynhans Posts: 78
    Thanks Vining - worked like a charm.
    Its so frustrating having to guess but am hoping that lvl 2 will shed some light on the mystery's =)
    Now to try and get feedback on volume : /
  • PhreaKPhreaK Posts: 966
    Nice one. Be careful attempting to always reconnect on the offline event. If you're playing with IP comms get nice and friendly with the onerror event. Here's some of the codes that are found in data.number to get you started:
    • -3: unable to open communication port
    • -2: invalid value for protocol
    • -1: invalid server port
    • 2: general failure (out of memory)
    • 4: unknown host
    • 6: connection refused
    • 7: connection timed out
    • 8: unknown connection error
    • 9: port already closed
    • 10: binding error
    • 11: listening error
    • 14: local port already in use
    • 15: UDP socket already listening
    • 16: to many open sockets
    • 17: local port not open
    These are for both servers and clients so some will only apply to one of the other.
    For me, I prefer to just set a flag in the online and offline handlers. When I fire the IP_CLIENT_OPEN function, I set the flag to a third state to indicate the connection is pending.
    If the connection needs to be open all the time, I either run a timeline or a mainline check if the flag is off ... and if it is, that's where I open the connection, with a timeout that will change that flag from the pending state to the not connected state if anything goes wrong. I can then play with the status of that flag depending on what error code comes back and respond accordingly. In my experience, a delay of 30 seconds or so is usually appropriate between failed attempts to let the port settle down.
    If it's the type of connection that is only open for a single exchange, then closes automatically, I'll only open the connection when I have something to send. The rest works the same.
    Thanks for the replies and tips, it seems very stable and commands outbound to the amp are perfect.
    I am now trying to capture data back with some difficulty.
    I have thrown this in to see what is being read by my 2100;
    DATA_EVENT [dvOnkyo]{
    string:
    send_string 0, "'Onkyo Amp Says',data.text";
    and its only showing the first four characters of the string (ISCP). The full string should look something
    like;
    ISCP{00}{00}{00}{10}{00}{00}{00}{13}{01}{00}{00}{00}!1NTM02:46/04:34{1A}{0D}{0A}
    I read on one of the posts that the master stops receiving the incoming info if it reads 00, is this true?
    The plan was to try and receive data on the 2100 and then parse out individual messages and eventually
    use these for feedback on the TP..
  • HedbergHedberg Posts: 671
    Probably, what you are seeing depends on the application that you are using to look at the diagnostics. My favorite telnet program is called Indigo http://www.shadeblue.com/ and it should handle the $00 characters properly.
    Alternatively, you can create a string and examine the string in debug displaying as hex. Something like:
    character sDummy[100]
    string:
      sDummy = data.text
    In all likelihood, you'll find that your string is arriving correctly and you can use whatever string manipulation functions you desire to parse it.
    To answer your question directly: It is NOT true that the master stops receiving when it finds $00 in the string. It's just a display (human interface) issue.
    mkleynhans wrote: »
    string:
    like;
    The master will receive and process the 00 "null" but it won't print it (send_string 0). It you want to print it you'll need to convert to something that diagnostics can process. There's a few functions on the forum that basically do a find and replace and another that will convert hex to ascii for printing to diagnostics. HEXBUG or something.
    Thanks as always for the replies - am loving how powerful AMX is coming from an RTI background.
    It seems that the possibilities are endless.
    So I have go this far and am still only receiving the ISCP part, not any of the middle section or the actual code
    that I am looking for...
    string:
    stack_var char cMsg[50]
    SELECT
    ACTIVE (find_string (data.text,'!1MVL',1)):
    cString = data.text
    cVolume = left_string (cString,5)
    SEND_COMMAND dvtp, "'^TXT-100,0,',cVolume"
    In the text box, I am seeing ICSP but nothing else.. Have tried a few different combinations in the cString length and mide, am going to
    keep trying but it looks like I am only receiving the first four bytes. Any ideas where I am going wrong?
    Cheers,
    Mike
    =) Answering my own questions here but have sorted it, I needed to mess around the mid_string start point.
    Sorry for all the silly questions and thanks for all the help guys!! Am well chuffed.
  • What was the code you used in this case?
