TP Design4 v3.1.643 Installation
bartliew
I encountered trouble installing the latest version of the software on my machine running Windows Vista Home Basic. Appreciate if anybody can provide the solution. Thanks! :-)
Note to admin: Please turn on the img tags.
My XP laptop updated fine.
Guess it's worth a try for you as well.
I find I have to do this with almost all installs on my Win7Pro machines. I cannot run the installers from the web or installer .exe's from a server drive. I have gotten in the habit of putting the installer .exe on my desktop and running it from there. If I still have trouble, I have to go into the .exe's settings (right-clcik>properties) and making sure it's running in Windows XP Pro compatibility mode.
I'm running 32-bit XP anyway, so I don't have that issue. Did install it from a network drive though.
Yeah, XP had no problems with this at all in my experience. Win7 kinda settled down quite a bit after a few updates and hot fixes. I don't have much trouble with it nowadays.
Yes it does. A constant source of irritation.
yep, and I had forgotten what a pain in the arse it is moving those toolbars around to re-organize, you move one a pixel too far and the whole mess starts jumping around.
regards
thanks in advance
Since I did this blind, not knowing the problems it would cause, you might be able to avoid the no-boot scenarion by copying msvcrt.dll back before you restart. I would certainly try it, but it might be set to replace at next reboot in any case, so make sure you have the backup and a way to restore it beforehand.
I am stunned that AMX hasn't fixed this yet. I called it in immediately. It likely only affects certain configurations, but it's clearly a matter of the wrong msvcrt.dll version being matched to the OS when TPD is installed.
I installed this originally on my Windows 7x64 desktop - no problems.
Installed on a Vista x64 - got the msvcrt.dll error. Had to jump through all kinds of hoops to get it installed, including changing permissions on the file so it could copy, then dealing with an unbootable laptop requiring a boot disk to repair it.
Just this second installed on another Windows 7x64 laptop - no problems. This despite spending about an hour preparing a new repair disc and making a copy of the original dll so I could recover from the inevitable problem - only for it not to occur!!
EDIT: Found link for archived version: http://www.amx.com/techcenter/downloadConfirm.asp?fn=/assets/applicationFiles/archive/TPDesign4_3.0.634.zip
regards
Note also that the new TPD4 has problems with some fonts, positioning the character out of line.
See the solid forward arrow in AMX ICON, ideal for PLAY buttons. In all versions before, it lined up with all the others. Now this release renders the arrow lower than all other characters. I had to substitute a similar character from AMX ICON 3 with a larger point size to replace it.
I found a few other characters in other fonts that do the same, only in the new TPD4. No pattern I can find. A real pain to step around.
And I'm no fan of copying a popup and pasting it and having no choice of renaming it now... as you always could before... it simply pastes as "Copy of xxxx" but of course up in the C's not where you expected to put it. More scrolling.
http://www.emptyloop.com/unlocker/#download
I didn't noticed that.... good to know
Kostas
