access code to TP page
HI ALL
i need to make login button to TP page this button didnot flip to the secured page without entering the right pin code.
please help
    You can do it in either TPbDesign by making the button do a page flip and then setting that button's security settling to ask for a password or perform thevfunction from code.
  • kfahmykfahmy Posts: 5
    is this the code do the required function??
    CREATE_BUFFER TP1, TP1_BUFFER
    DATA_EVENT[TP1](* EVALUATE TP1 DATA *)
    STRING:
    SELECT
    ACTIVE (FIND_STRING (DATA.TEXT,'PAGE-',1)):
    JUNK = REMOVE_STRING (DATA.TEXT,'PAGE-',1)
    CUR_PAGE = DATA.TEXT
    ACTIVE (FIND_STRING (DATA.TEXT,'KEYP-',1)):
    xxxx (* keypad code *)
    ACTIVE (FIND_STRING (DATA.TEXT,'KEYB-',1)):
    1234 (* keyboard code *)
    ACTIVE (1):
    1988 (* default code *)
    CLEAR_BUFFER TP1_BUFFER
    ONLINE:
    SEND_COMMAND TP1, 'TPAGEON'
    This code will get you the current page or whether or not the user has entered a strung from either the keyboard or key pad.. You still need some code to do something with that information. It's pretty basic string parsing, however.
