RS232 - I need more outputs
 davidv
davidv
                                  in AMX Hardware
                    I need more RS232 outputs.  I have 12 outputs that I need and the NI4100 I believe only has 7.  What are my options?  Do I really need to buy another master to get the outputs I need ?
http://www.amx.com/products/NXC-COM2.asp
That will net you 13 RS232 outputs.
The AXCENT3 PRO has slots like the Netlinx, and you can add still more cards... of the older variety.
There is a list of buffer sizes floating around. Regardless of what it says, I would not use Axcess serial ports if you expect strings longer than 50 bytes in one shot.
When and Axcent3 is in slave mode I think all the traffic is shunted over AXlink (@ 20,800 baud) to the NetLinx master for the NetLinx to process. This is a bit of a bottleneck for the data, since each string coming into each port of the Axcent3 (presumably) needs to be wrapped to fit within an AXlink packet. If the incoming string is long it would probably be chopped into multiple AXlink packets.
Having said that, if your extra RS232 devices have a simple protocol this is a good solution, and I do exactly this on one of my "non-standard" lecture theatres. I agree that the Axcent3 is reliable & robust - power supply failures are the only issue I've seen.
Roger McLean
Swinburne University
