Change RSS length
jfigg
Hello,
We are using the RSS news feed module to pull in news/updates from an RSS feed on our webserver. However we’ve noticed that the player will only pull in so many characters of the feed from the server into the player. Does anyone know how to set the max # of characters from an RSS feed to be displayed on the player?
What is the max length currently set at ?
Does this limitation only apply to the RSS parser or does it also apply to the XML parsers ?
Without understanding this, one might think that lengthening the duration of the message would allow for more content, but it only slows the scroll down. The physical width of the message remains fixed. Messages that have fewer than ~150 characters also exhibit the same behavior, but it is shown onscreen as blank characters - or space between messages.
Each template field has a fixed character limit, and depending on the screen region and/or template, these counts are different. If it is not alredy on the website, Technical Support or your Sales Representative should be able to provide you with the template content guide that contains this information.
A feature request for dynamic message length based on XML content length would need to be sent in through either Technical Support or your Sales Representative.
