ni 3100 can't load program
in AMX Hardware
hi, i'm on site....i can see the device tree, it just won't let me load the program any longer. i can connect to the master in can load to the touch panel... but any time i try and send a file to the master. the file transfer fails. i can reboot the master and every thing works. but i need to make changes and i'm connected Ethernet, every time i go to load it fails.
thanks
thanks
i have connect straight to the NI-3100. i can connect to the unit, i can reboot the unit, but i can't load to the unit
i have done that, but i will do it again just to be sure....the file i'm loading has the same ethernet address.....also i just did a hard power reboot.... basically nupluging the system
yes, i can ping the master. i can operate all the diagnostics functions....i just can't seem to load to it....i'll try and telnet to it. i can see all the device's online
trying now
switches 1,6,7,8 are on....still can't load program
i can telnet in to the system
i still can't send the program to the system (ni3100)
i was loading code and making changes just fine until it just stopped....i'm trying to check the memory now...and i have used this same code at another location...last tuesday....this is an identical project with a few minor changes
i have been trying to just upload the source...i did notice that if i telnet in to the system with dip switch one down. i get a weird feed back...when i telnet with dip switch one up it gives me a clear prompt......now i'm trying to check the memory and now i can't seem to connect at all.....i'm rebooting everything to see if a i can get a connection back
question?....when i reboot with the dip switch 1 in the on position should the status light come on? i just have the link light flashing and when i try an connect it goes solid
the processor did lock up....got a replacement everything works fine
