3 AXR-RFs and perfect harmony?
I have a job with 3 AXR-RFs installed - One is a 433mHz, and the other two are 418mHz. All 3 are declared in my programming. Do I actually need to add programming for both 418 Gateways, or can I just program for one, and assume that they will both pick up the same 418mHz button pushes? The two 418s are in place because I have a total of 3 R2s, but obviously I only have two frequencies to work with.
    The two 418 receivers won't know the difference between which remote did what. And depending upon whether or not the a given remote is close enough to each receiver, you'll get a push from both boxes. So unless you can put the two 418s far enough away from each other, I'd avoid trying them together.
    The the question of if you have to program for all three, YES, they will have different AXLINK addresses, and each will pass what it hears independently.
    As Eric said, you also have to deal with crosstalk. If both receivers can hear both remotes, you will have only confusion.
