Nexia CS Module
Does anyone have a module for a Nexia CS?
  • You can use the Biamp Audiaflex module that is on the AMX website. Audia and Nexia both use the same protocol.
  • davidvdavidv Posts: 90
    Biamp volume ramp
    I just want to ramp up volume for input 1 and input 2 individually. There are no other inputs. The module is over kill. Anyone skilled with Biamp that could help?
    Sounds like something you could knock together yourself in pretty short order then.
  • The easiest way would be to open up the Biamp file, then look in the help file. All of the RS-232/Telnet commands are listed there. Just look for the type of block you want to control. As a help, the typical command looks something like:
    SET 1 FDRLVL 2 3 4.0$0D$0A
    1 is the device ID, 2 is the instance ID of the block you want to control, 3 is the channel number you want to control, and 4.0 is the level.
