Promethean PRM-35/EST-P1
Hi,
Any one successfully controlled a PRM-35/EST-P1 projektor from Promethean?
They have used to have have Sanyo projs. inside, but they seem to have changed OEM provider...
The codes are now:
Power ON:~PN<CR>
Power OFF:~PF<CR>
Input RGB:~SR<CR>
And so on...
I haven't managed to get it up and running yet...
Anyone familiar with either the model or have seen theese codes before??
Kenneth
The codes are now:
Power ON:~PN<CR>
Power OFF:~PF<CR>
Input RGB:~SR<CR>
And so on...
Kenneth
Those codes are pretty straight-forward. Post your code. Perhaps there's a problem there.
or this document lies(attached).
Actually the document is only "named" PRM-35/EST-P1, so i actually don`t know wich model it is intended for.
Anyway.
Tried the codes out on a EST model(which should use the same protocol as the PRM-35), and it worked fine.
So the PRM-35, wich is out with the customer needs to be swaped(or i need to find the correct codes...)...?
Kenneth
Didn't work
Kenneth
