Adding AxLink devices
soma
Hi All
I stumbled upon something and it would be great to hear your tipps and opinions.
I have a relay box which is connected directly to AxLink. Now I can create a SNAPI module with Cafe Duet which provides functionality to switch relays. The Code Builder provides the function and the code is generated correctly.
BUT: I cannot connect the module to AxLink but only to a NI-Relay as the connection type is 'Relay'
Is there a possibility to add an AxLink device? Or is this just not possible?
How would you deal with that if you want to provide a simple solution to those who use VA?
Thanks for any hint.
Sorin
Sorin
There is no real difference on how to control an axlink relay device versus a netlinx relay device. The device address instructs the code what device to control. On the AxLink device there is a set of dip switches that assign the address of the relay box. You can use the AMX program called "DIP Switch" to set the switches correctly.
Let say you set the dip switch for address 96.
The correct DPS for this address is 96:1:0.
To turn on relay 1 of the axlink device.
On[96:1:0,1]
Thanks for your reply. It seems I did not make myself clear. I have been an AMX programmer for several years and I do not have any questions on how to control a relay in general ;-)
I try to create a Cafe Duet module which can be used by VA users to control a relay box which is connected to the AxLink bus. I wrote such a module and implemented the necessary SEND_COMMANDS (eg. 'RELAYCHANNELSTATE-1,ON'). I added the module to VA and I am able to drag it to the main screen.
The only thing I can't do is to get the module to connect to the AxLink bus because apparentely it is not possible to add a 'native NetLinx device'. Our module box contains a AXP-CPI16 and is connected directly to AxLink.
So for now I always have to change the device after generating code. I'd like to assign the module a device in the AxLink range (1-255) so I don't have to do that manually.
I hope this helps to clarify my question.
-soma
one possible solution i can think of is the use of 'custom.axi'. I am not an every day VA user but maybe with some effort you will be able to connect your module to another device (virtual ?) and in the 'custom.axi' you can link the trigger of the 'other' device with the relay.
Kostas
Sounds like what I need. Can you be a bit more specific? I am an experienced Java and NetLinx programmer but I have no real experience in VA... How to deal this custom.axi? Is there a documentation?
I will do some research later. Thanks for your reply.
-soma
