Aprilaire 8800 in an existing 8870 system
I have a client who is expanding their system. The expansion will add three new thermostats. All we were able to order were 8800's because the 8870 is now unavailable. Has anyone used 8800 and 8870's side by side in the same system? The protocol docs say the 8800 protocol is the same with additions for scheduling. FYI, I am using the duet module for the AMX Viewstat to control the 8870's and hoped to just add the 8800's to the distribution panel with new addresses.
Have they published the amended protocol? If you're using the duet mod you may be able to adapt the code by using the pass back and pass thru commands but you will have to make these modifications to use the new control commands yourself.
Have they released documentation for schedule protocol? When we last asked, they said it was not planned for remote control. Seemed short sighted but that's what support was saying. Hope it has or will change...
FYI, I'm told the process for setting the device address is different, but nothing else about it... this is second hand but trusted....
If they're to be used remotely with in room sensors that would be ok but if they're being installed in the room they serve then you have potential user issues. They may enter program mode, place on hold, etc. the price is about the same if I recall but they can potentially create problems. Personally I prefer the stats to be remote with sensors in to rooms but sometimes that's not an option.
I was looking at the manual and it says the dist panel is a model 8819 so maybe its different than the 8818 of old. Maybe that's part of your problems if your still using the 8818? I just wired for a new install but haven't yet played. Hopefully these bugs will be resolved by then. I hope!
edit#1
I would assume that you can't mix T-Stats either so it's all of one or the other on the proper dist panel unless you use 2 serial ports and connect one to an 8819 dist panels while another serial port talks to the 8818 dist panel. I would have naturally assumed that you could just pull out an 8870 and replace it with an 8800 but it doesn't appear to be the case.
edit#2
Ok reading down to JNs post I found they do provide for a combination of 8800s and 8870s wired to an 8818 dist block so forget everything I just said!!!!!!!!!!!!! Just scrolled down further in the install manual and it shows what JN says it did. Still no ref though or ability to power the T-Stat from the common supply.
Why didn't they build this isolation into the t-stats? It's mind boggling! Didn't they test before production?
