AXIS IP Camera Module
Hi everyone,
I have an AXIS 241Q encoder which is hosting my CCTV camera at a local IP address. I need to be able to control this PTZ Camera from my touchpanel, ie: move up, down, left, right, zoom, go to preset.
The camera only supports control over a http interface. For example in my web browser I can type:
http://*myCameraIP*/axis-cgi/com/ptz.cgi?move=left
...and the camera will move left. I'm fairly new to this game and never seen this before. Wondered if anyone out there has programmed anything like this before, or maybe even someone has already programmed an AXIS IP camera (I think they all use the same API).
This is something I got from AXIS:
An example of the command for the telnet:
shttpclient -u (username for the camera) -w (password) "http://127.0.0.1/axis-cgi/com/ptz.cgi?move=up"
Although sending this string over IP after connecting on port 80(http) nothing happens.
Any help or ideas would be appreciated!
Thanks in advance guys,
Luke
Luke
you need a few things, base 64 encoding, and http protocol docs,
you will have a header that will contain the security info, and the http command will be
GET /axis-cgi/com/ptz.cgi?move=up HTTP1.1<cr><lf><cr><lf>
ill see if I can dig somethin up
I don't know why they would give an example using an IP of 127.0.0.1 since that implies you're trying to control the camera from the camera.
edit:
added link to module http://www.amxforums.com/showthread.php?6457-Axis-Camera-213PTZ
Yes, the standard port is 23 but technically you can run a telnet session from any TCP port. I've seen pretty much nuts to soup.
move=<string>
home,
up,
down,
left,
right,
upleft,
upright,
downleft,
downright
Absolute: Moves the device 5 degrees in the specified direction
Relative: Moves the device approx. 50-90 degrees in the specified direction.
Clearly by default it using the relative option above, whereas I would want absolute (smaller, usable movements). Axis won't talk to me as I'm not a part of their ADP program so I was hoping someone out there would know how to use this.
Thanks - Luke.
Hi Luke
Guess i had the same problem.
The commands, "absolut", "relative" and "digital" depending on the firmware installed on your axis cam, you cant choose between them.
In october axis will release the Firmware 5.4 and with this firmware the 25% move command works.
(moves always 25% of the picture you see)
You could also try the "rpan" and "rtilt" command with those you can choose how many degrees the cam should move, but then you must process the zoom value first, to get something similar like the 25% command.
tried to attach the beta firmware 5.4 for an Axis Q6034 cam but the file is to big to upload... (18Mb)
Hope that helps
Manuel
