Compact flash image
Does anybody have a compact flash 512 image backup for a mvp8400?
  • mushmush Posts: 288
    sickkick wrote: »
    I have a few different images in the following formats..
    Norton 'Ghost 2003'
    ComPuApps 'OnBelay V2'
    Linux 'DD'
    The size of the CF card is not that important as that can be changed later, what is important however is that the firmware on the CF card is the same as that on the panel.
    If you try to boot a panel that has different firmware on the CF card you can have spurious results including not booting.
    My images are firmware version v2.86.55
    Cheers
  • That will work. I can do compuapps or linux, Could you please send me a copy?
    mike@jbmediasystems.com
    sickkick wrote: »
    I've sent you a Drop Box link to download the file.
    It’s a zipped 64MB image so you will have to restore to your 512MB CF card and then resize the partition.
    I use Partition Wizard which you can get for free from here http://www.partitionwizard.com/download.html
    Let me know if you need more information.
    Cheers
  • Thank you very much.
    sickkick wrote: »
    No worries, let me know how it goes.
