NEC Tuner control
I have a tuner inside the Option slot of an NEC monitor. I can control channel up/down but can't find a way to input the channel directly via RS232.
I have searched every where for the protocol.
Does anyone know how to control this tuner?
thx
thx
how old is the TV? Do you have the model?
Kostas
The tuner is a card that slids into the side. The tuner model is MPD-DTi.
I can control channel up/down but I really need to have direct channel selection.
I don't want to have to use IR for direct channel select if I don't have to.
Kenny
On the phone for nearly an hour and the tech finally discovers the doc.
http://www.necdisplay.com/documents/UserManuals/ExternalControl_P402-P462-V422-V462-V651-X461S-X551S-X551UN.pdf
