MVP-900i in a coma
in AMX Hardware
I have a new MVP-900i in my office that was working fine for the last month up until this morning.
The TP dropped offline and doesn’t show up in the online tree and the screen is completely black as if there is no power. However, the TP is plugged in and the little blue LED at the top right corner of the panel is lit so I have to assume it’s getting juice. But other than that LED being lit the panel is completely dead and unresponsive.
Has anyone seen this happen before?
Yep, multiple times.
You can't shut it down by holding down the bottom capacitive buttons. There's a reset button hiding behind where the stylus slips in that will reset the panel if you hold it for a couple of seconds.
I've also had issues with them locking up when I did TP files transfers while remotely connected (VPN to remote network) and VNC'd into the panel. They don't like having a VNC connection when they go into a reboot. They usually don't come back and you have to physically reboot it to get it back. Other times you just loose the user pages.
They're pretty flaky if you ask me.
I just tried the reset button several times and up to 15 seconds but still nothing.
It's just plain dead except for the blue LED.
Anyone got a set of defibrillator paddles handy?
Clear...
When I plugged the TP back in this morning it booted back to normal.
The power settings are set to Standby=Off, Shutdown=Off, and Sleep=2 hours.
I don’t know what caused the comatose state.
Revived the panel by disconnecting/reconnecting the battery.
But now i don't know what to say to the customer, and how to prevent this from happening again.
Have a look at the cache memory settings and get it to clear regularly. This has been a problem with previous MVP screens. I have had this problem with MVP 5150, 5200 and 43x screens. The lastest firmware upgrades has fixed this problem.
I guess it's the same everywhere!
I never changed the cache defaults or even thought to look at it. What do you use for cache settings? My Image Cache Settings are set to:
Flash Cache Size = 0 MB
Cache Expires = Never
Image Cache Settings = Off
So if I’m reading it right it looks like the panel is not using a cache at all. Maybe that’s the problem?
Thanks for the feedback.
I will investigate more about the cache memory usage.
It's been a while since these setting have appeared and no one has really discussed them at all since so why do you change their values and where did you gain your insight, are you under cover AMX?
After reading this I don’t think the cache settings were the issue as the TP file that was loaded at the time didn’t have any dynamic images.
