Control Panasonic projector via IP
Hi,
I'm trying to control a Panasonic beamer via IP.
Using the PJlink protocol ... I'm able to control the Pana beam via IP.
Their RS232 protocol is sooo simple.
But for 1 or other reason it's not so smooth for me via IP ... grrrrr
Someone succeeded to do this ?
Prepared to share the string sent to the device ?
fyi ...
1. passwords are disabled on the pana beam
2. I control many many other devices via ip, so I'm not a newbie
Many tx in advance !
Mike
  • Control Panasonic projector via IP
    Try this :)
  • PJLink module works fine with Panasonic. The only issue is that you don't have AutoImage function. But this is a general PJLink related limitation.
  • MikeXMikeX Posts: 5
    Tx Bruno for that module.
    Did you attached it as a hint to use MD5 ?
    The PJlink works and is very easy to implement.
    Example ...
    IF(!PROJ_STS_IP) IP_CLIENT_OPEN (DV_PROJ.PORT,IPADDRESS,4352,IP_TCP)
    WAIT_UNTIL(PROJ_STS_IP) SEND_STRING DV_PROJ,"$25,$31,$49,$4E,$50,$54,$20,$31,$31,$0D"//RGB1
    But as Marc mention ... no auto adjust, aspect ratio, ... and some other interesting functions.
    Grtz
    Mike
  • alanhalanh Posts: 30
    Panasonic IP port
    Control via IP of the Panasonic projector range, is the port 1024 as mentioned in the panasonic network booklet or 4352 as detailed in the above post, anybody know for sure as doing a panasonic next week over IP.
  • I've controlled many PJLINK projectors in the past, including Panasonics, and it's always been on 4352.
    Anyone controlled Pana projectors via IP, but with the full featured protocol instead of the PJlink ?
    PJlink has only basic functions.
    Imo a bit stupid to foresee a IP/RS232 gateway (Extron, Global Caché iTach, ...) to have full control.
  • toddttoddt Posts: 28
    Moxa NPort5110
    I have controlled both Panasonic projectors and plasma's with the Moxa NPort5110. Worked rather well. Only problem that I had was the return strings were a bit off, I had to look at them all in hex. I just did a watch and adjusted to what I got back. Pretty easy set-up and nice to not have to run long 232 cables or a axb-232 box with axlink. Just set up client/server communication and then just send normal 232 strings.
    You could always use the new ICSLan (http://www.amx.com/products/EXB-COM2.asp) devices if you have a fully functional RS232 module. The cost of this box could be justified by reliable operation and time saved programming the IP version of control. Unless you are planning on using these projectors on a regular basis.
  • define_call 'beamer connect' {
    ip_client_open (10,'192.168.40.3',1024,1)
    define_call 'pana on' {
    //send_string dvbeamer, "$02,'ADZZ;PON',$03"
    call 'beamer connect' // needs to reconnect every time ...
    send_string dvbeamer, "'00PON',13" // every command disconnects the beamer
    define_call 'pana off' {
    //send_string dvbeamer, "$02,'ADZZ;POF',$03"
    send_string dvbeamer, "'00POF',13"
    define_call 'pana shutter on' {
    send_string dvbeamer, "'00OSH:1',13"
    define_call 'pana shutter off' {
    send_string dvbeamer, "'00OSH:0',13"
    define_call 'pana rgb1' {
    send_string dvbeamer, "'00IIS:RG1',13"
    define_call 'pana rgb2' {
    send_string dvbeamer, "'00IIS:RG2',13"
    define_call 'pana video' {
    send_string dvbeamer, "'00IIS:VID',13"
    define_call 'pana svideo' {
    send_string dvbeamer, "'00IIS:SVD',13"
    define_call 'pana dvi' {
    send_string dvbeamer, "'00IIS:DVI',13"
    define_call 'pana sdi' {
    send_string dvbeamer, "'00IIS:SDI',13"
    define_call 'pana query shutter' {
    send_string dvbeamer, "'00ADZZ;QSH',13"
    define_call 'pana query input' {
    send_string dvbeamer, "'00QIN',13"
    define_call 'pana query power' {
    send_string dvbeamer, "'00QPW',13"
    define_call 'pana query lamp1' {
    send_string dvbeamer, "'00Q$L:1',13"
    define_call 'pana query lamp2' {
    send_string dvbeamer, "'00Q$L:2',13"
    define_call 'pana query lampstatus' {
    send_string dvbeamer, "'00AQ$S',13"
    HTH
    Alexander
    tx alex ! I'll give it a try when I'm back on-site. grtz
  • i know this is a year later :)
    but security is what prevents the projector from communicating with the standard RS-232 module over IP.
    Use the web control page and set the password to nothing.. then the security will not apply on NT control or PJLink control.
    default username password is admin1/panasonic.
    i also open the port manually, as the module didn't seem to do the right job. will do some more verification on that side yet.
  • travistravis Posts: 180
    Try this :)
    stealing your MD5 sum function. Thanks.
    It was easier than walking out to where the projector is and deleting the password.
  • travis wrote: »
    you didn't have to walk, it can be done from the browser :)
    Ah you're right. I was distracted by the fact that you can't get to the test patterns or enable PJlink through the web UI. On this model at least.
    So, I'm working with a PT-ST10U
    When you tell it to stand-by over PJlink, it turns off the NIC. Um, I think I might need to turn it back on over the network too, guys.
    edit: found the eco setting and turned it off.
  • I'm working with a PT- DW740 right now. I've used the AMX module for the 730.
    There is no direct HDMI support in the module, so I use a pass thru command of
    send_command vdvPanasonicPTDW730S,"'PASSTHRU-IIS:HD1'"
    Once I removed the password, this module works fine. Power On is good from Standby.
    edit: just saw your eco mode edit.. yes, that did get me as well. It must be off for the ethernet port to remain live. :)
