Channels ("real" and virtual) Vs. Variables
So I've been having this problem creep up every so often and was wondering if anyone has experience the same thing, and if so what your fix was.
On occasion I'll use device channels as a ready / busy / online / offline flag. They're global across everything (modules, master-to-master, etc.) so they're, IMHO, rather strong. On two particular modules I've written that use channels as a notification flag, the channels will get into a major tissy and flip on / off about 1,000 / second, and won't stop until the system is rebooted. The system continues to run fine, it's just whatever depends on those channels ceases to work anymore. On these two modules, they're both IP devices, and I used the 'actual' device's channel rather than the virtual, i.e. [0:40:0,251].
Has anyone ran into this? I've considered using a variable as a flag, but you don't get the 'notification' like a when a channel goes on / off. Thoughts?
Interesting. I have been seeing something similar when using the Kaleidescape module. For no reason that I can think of, a channel will start to toggle on/off hundreds of times a second, slowing the system to a crawl. A reboot fixes it usually, but I've even seen it start up again immediately after a reboot. Its always a channel used by the Kaleidescape system so I figured it was the Kaleidescape module code, but now I am wondering. The KServer is an IP device as well. In this case, its a devchan that toggles and the device is the port ie: 0:4:0. Could there be an issue using the real port on IP devices where channels will get toggled incessantly? Hmmm.
The idea being only turn on the channel if it's off but don't try if it's on. Also, in olden times, a subsequent channel on would not fire if the channel was already on.
The fix was to track the channel state with a valuable.
I *know*, I *know*, I KNOW! that we were told to never rely on a 'real' device's channel for anything, including feedback . . . I just never ran into a problem with it until now. Going to move to virtual to see if it helps. (I suspect it will.)
I use real devices all the time without issue, except not IP ports. My guess is that there is something special about the port device that gets these channels toggling incessantly. I just logged into the system I was seeing this with and I turned the channel off in control a device and this stopped it cold. Guess I get to dig into the Kaleidescape module once again
If you need that guarantee I guess, but I don't find I ever do. Is that for when you use define_combine and those features?
I don't use define_combine or anything like that, but I believe that's what that 'feature' was intended for.
This code should run fine no? If the panel is offline [dvTP,1] is off, so no need to turn it off, and if its online it should work fine too. I'm not seeing the issue there.
I don't use define_combine as i prefer to create arrays of devices then address them individually or as a group at will.
Think something mission critical, it was just an example; mission critical like this:
I'll toy around with IP devices and their channel properties.
I've seen this.
I have added a second port to virtual devices as a channel feedback mechanism. Worked just fine. Be sure to set_virtual_port_count=2 in the module code.
dvDevice= 33001:1:0
dvDeviceStatus=33001:2:0
How can the online/offline events for the device trigger if they are always available? I think this is where you guys are running into problems.
I will have to take a look at the KScape module when I have a chance because I use it all the time and have never had an issue with it (other than excessive CPU usage).
The device is always available (device zero), yes, but that port isn't always available.
I wouldn't rely on a channel state on a touch panel for that. The only thing I ever use that for is to provide feedback to the panel, so if its offline, then it doesn't matter.
Sounds like classic duelling channels to me.
There are lots of ways the behaviour can inadvertently be embedded in code without ever being obvious until you run into the problem. Effectively there's a feedback loop causing the channel to toggle which could be initiated in an event, timeline event or define_program and the problem code could be a long way downstream hidden in functions that have been called by functions that have been called by functions.
The same sort of thing can cause levels to constantly jump about too.
As you stated devchans are globally accessible, so code anywhere in the system could be causing the behaviour. The problem code doesn't necessarily have to be in the module you're expecting to find it in, it could be in the main program or potentially even another module.
As a tip, TRANSLATE_DEVICE can help to break these sorts of feedback loops and stop the main program being able to affect the channels and levels being used as an interface to a module.
That's one nasty bit of code. You have to possess a truly evil mind to come up with that one.
This is true and the Kaleidescape module has all sorts of that going on. They even use a recursive function for message parsing which just seems to be asking for trouble. Flipping channels in channel events that then flip other channels that depend on a variable in mainline, etc so its pretty ugly. Very difficult to trace if a problem like this pops up. I don't use devchans, combines or define_program for this reason, as it makes tshooting a nightmare.
I've never come across translate_device before and don't see any documentation on it. Is there anything in the docs about this keyword?
Why thank you *blushes*. You should see what I can do with a bit of recursion.
There's not much documentation of it anywhere. The example source for a module posted by John Michener in the following post is probably the best demonstration.
http://www.amxforums.com/showthread.php?1926-The-not-documentary-function
Effectively translate_device is used inside modules to create an event wormhole between two devices. One device is likely to be a parameter passed to a module (let's call it vdvParameter), the other is likely to be a DYNAMIC_VIRTUAL_DEVICE (I'll refer to it as vdvInternalToTheModule - we don't care about the device outside the module as it is only ever referenced inside the module and may as well not exist as far as the rest of the program is concerned).
When an event is initiated on one device, the event that is fired will occur on the second device only.
ie. on[vdvParameter, CH_SOMETHING] will result in CH_SOMETHING being turned on on vdvInternalToTheModule and vice versa.
It is therefore not possible for code outside the module to set the state of any channels on vdvParameter (or generate level events, or data_events, etc.). The events are still generated, but they are fired for vdvInternalToTheModule and the programmer can handle them as required inside the module.
If the programmer wants a channel to go on on vdvParameter in order to provide feedback to the main program, they need to turn on that channel on vdvInternalToTheModule.
Bit to get your head around, but very useful and a very powerful way to stop code external to a module influencing the operation of the module by altering the state of the interface vDev. Effectively you're making the interface device read only.
